oxygen sensor problem help?/
ok i did a engine swap on my crx jdmd15b controlled by p28 ecu w/locash harness the p28 was already chiped with an na chip so got everything going but had a check engine light for o2 sensor got a new one still did the same thing for check engine light
now the main ?
i have a turbo kit i put together while i was doing the install got a base map made up for it this is what the kit consist of
all brand new V
t/25 @8psi
blitz bov
jrc fmi
sre charge piping
greddy manifold
dsm 390 injectors
stealth mode oil lines
with the check engine light for 02 sensor would it be a bad idea to install the kit now with the base map till i get tuned or should i fix the 02 sensor problem first ??
dont wanna hurt the fresh swap and have to do it all over agian
thanks alot brent
now the main ?
all brand new V
t/25 @8psi
blitz bov
jrc fmi
sre charge piping
greddy manifold
dsm 390 injectors
thanks alot brent
what harness did you use on the engine? what specific code is it? range performance or a heater circuit? if you used the crx harness you will have an issue with the heater. you may not have the wiring for a heated o2. in any case i would get the problem resolved before you put the huffer on.
wiring was done by locash wiring harness wich comes directly from the p28 ecu hmmm the 02 sensor has a black grey and two whites the two whites are power and heater would they make a difference if there switched cause there both just a 12v??? bosch 02 sensor
turbo kit isnt installed yet wondering if it was ok to do that with the 02 problem ..............i have a basemap for the turbo once its installed will it affect anything with the 02 being bad with a turbo on?
Who is Mr Robot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">were the o2 heater disable and all that checked in the bin before it was burned?
answer the question.... its not you o2 sensor thats bad... its the burn on the chip you have. some of the options probably werent properly checked off
elliotEk
Honda Civic (2006 - 2015)
Jul 6, 2012 02:50 PM
stripes777
Nov 30, 2009 07:24 AM
se93
Oct 7, 2002 07:00 PM
