Oversized OEM Head Gasket?
Old May 25, 2004 | 05:43 AM
Si Integra's Avatar
Default Oversized OEM Head Gasket?
I was told recently the OEM headgasket will not work on a block bored .20 over. Previously I researched this topic and was reassured that it would fit fine as oem headgaskets were larger than the actual bore anyway.
I am looking to assemble my block tonight, so any help would be appreciated.
Thanks in advance!
PS, I will be running around 15-20psi
Old May 25, 2004 | 11:25 AM
Si Integra's Avatar
Default Re: Oversized OEM Head Gasket? (Si Integra)
No one knows?
Old May 25, 2004 | 11:35 AM
Too_Smooth's Avatar
Stock works...my bro's motor's was .20 over and we used a stock gasket without any problems.
Old May 25, 2004 | 12:27 PM
MaxBoost's Avatar
New User
Default Re: Oversized OEM Head Gasket? (Too_Smooth)
I think if your assembling your motor tonight, you shouldn't have a problem placing yur HG on the block and seeing if it fits. I dont think you should have a problem...
If you ever go over .20 though you will need to get a bigger bore gasket, you can get your oem one bored by GE, or you can get a cometic, hks, or blitz gasket.
Old May 25, 2004 | 01:44 PM
Si Integra's Avatar
Default Re: Oversized OEM Head Gasket? (MaxBoost)
Is there a way to check to see if it does not fit? I mean will it be real close to the edges? or should it be?
I dont know what to look for to be honest?
Old May 26, 2004 | 04:54 AM
Si Integra's Avatar
Old May 26, 2004 | 07:10 AM
B18C1CYA's Avatar
yes stock gasket will work just fine they work fro 81mm and 81.5mm= 20 over if you whent 40 over you would need a gem head gasket
Old May 26, 2004 | 07:13 AM
DaX's Avatar
DaX
Loved
Community Favorite
Just get GE and call it a day.
Old May 27, 2004 | 05:32 AM
Si Integra's Avatar
Default Re: (DaX)
I already purchased an oem one. Can any machine shop bore out an oem gasket? The edges are damn close to the cylinder walls. I am not sure about how safe it will be. I will be running this engine under boost.
Old May 27, 2004 | 06:56 AM
B18C1CYA's Avatar
Default Re: (Si Integra)
you will be fine the stock will work on 81.5mm bore
Old May 27, 2004 | 11:50 AM
Si Integra's Avatar
Default Re: (B18C1CYA)
Even if it is .03 over the .20 over. I have it at .23 over so the piston has room to expand.
Old May 27, 2004 | 07:18 PM
B18C1CYA's Avatar
iam not understanding so it is bored to .23 over?
Old May 28, 2004 | 04:51 AM
Si Integra's Avatar
I guess so, yeah. When you bore a turbo motor, you oversize it just a tad so the pistons have room to expand.
Old Jun 1, 2004 | 07:07 AM
X-Mazda 3 Racer's Avatar
Do not worry about it. The stock gasket can go 81.5 without a problem. The extra .003" is nothig to worry about. The factory gasket was made to handle an 81.5 mm bore with the side clearance taken into consideration. You will NOT have any issues! Best of luck with your car.
Vince Tiaga
Golden Eagle Mfg.
Old Jun 1, 2004 | 09:11 AM
Si Integra's Avatar
Default Re: (GoldenEagleMfg.com)
I am obliged, thank you all for your time!
Eghatchgsr8
Sep 19, 2014 02:24 PM
timm099
Jan 15, 2007 08:52 AM
ge_itr
Jan 9, 2007 08:58 PM
pinota
May 28, 2002 09:30 PM
BlackGSR
Feb 26, 2002 06:52 AM
