Overheating with new rad
Old May 13, 2006 | 04:42 PM
Mr.Death's Avatar
Default Overheating with new rad
I replaced my stock CRX rad with a Fluidyne 1/2 size rad and a 10" slim fan and am having problems with keeping engine temps down due to . I have my fan wired to be on constantly, installed a colder Jackson racing thermostat, bled the coolant and still thecar is running hot. The rad overflow is completley full which leads me to belive the rad car may be to blame. The rad cap is rated at 16 lbs. Should I try using the old crx rad cap or iam I better off with the fluidyne cap. Any help or pointers are greatly appreaciated.
Old May 13, 2006 | 04:44 PM
vtec.dc2's Avatar
Default Re: Overheating with new rad (Mr.Death)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Death &raquo;</TD></TR><TR><TD CLASS="quote">I replaced my stock CRX rad with a Fluidyne 1/2 size rad and a 10" slim fan and am having problems with keeping engine temps down due to . I have my fan wired to be on constantly, installed a colder Jackson racing thermostat, bled the coolant and still thecar is running hot. The rad overflow is completley full which leads me to belive the rad car may be to blame. The rad cap is rated at 16 lbs. Should I try using the old crx rad cap or iam I better off with the fluidyne cap. Any help or pointers are greatly appreaciated.</TD></TR></TABLE>
maybe your fan isn't flowing enough cfm.. and does it flow air in the right direction? do you still run a/c?
Old May 13, 2006 | 04:46 PM
Mr.Death's Avatar
Default Re: Overheating with new rad (vtec.dc2)
No a/c and it is blowing in the right direction. Please help
Old May 13, 2006 | 04:50 PM
vtec.dc2's Avatar
10".. is that the largest you can fit? and do temps go down if you blast the heat?
Old May 13, 2006 | 05:00 PM
Mr.Death's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">10".. is that the largest you can fit? and do temps go down if you blast the heat? </TD></TR></TABLE>
Engine temps do go down when the heat is on
Old May 13, 2006 | 05:08 PM
vtec.dc2's Avatar
Engine temps do go down when the heat is on </TD></TR></TABLE>
my guess is.. you might have to provide more air circulation. probably by upgrading radiator fan, i'm not sure if larger radiator will help or not..
exhaust leaks inside engine bay, wastegates without dumptubes can lead to overheating.. also, make sure everything circulates... btw, are you loosing coolant/oil? smoke?
Old May 13, 2006 | 05:17 PM
Mr.Death's Avatar
I am loosing coolant, I figured it was escaping out of the overflow. No smoking, oil looks good.
Old May 13, 2006 | 05:25 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Death &raquo;</TD></TR><TR><TD CLASS="quote">I am loosing coolant, I figured it was escaping out of the overflow. No smoking, oil looks good. </TD></TR></TABLE>
you defintately have to find the source of that.. normally, i'd have to add coolant 2-3 times after replacing radiator or even coolant flush.. but thats only 2-3 times.. if you have to add coolant on regular basis.. you have to find a leak. autozone and some alike places rent cooling system pressure tester. you'll be able to hear where the leak is. try a different radiator cap and just look for leaks all over the place. coolant should not escape from overflow bottle.. not from oem.. i haven't seen one that leaks.. yet.
Old May 13, 2006 | 05:53 PM
coneheadsracing's Avatar
Have you tried to leave the fan off for a while? Why not hook it up to a switch and turn it on only when your driving slow.
Old May 13, 2006 | 07:43 PM
turboteg2nv's Avatar
Default Re: Overheating with new rad (coneheadsracing)
What's your coolant ratio? 50/50? maybe you should try more water, like a 70/30 mix instead? also heard of adding a DROP or two of liquid soap just to break water tension, give that a shot.
Old May 13, 2006 | 10:28 PM
EK_GSR's Avatar
Default Re: Overheating with new rad (turboteg2nv)
i run 75 / 25 water to coolant respectively. also i have watter wetter. you should invest in that. it works... not a scam.
sure you are bleeding it all the way ??
over flow can be related all the way from bad rad. cap to head gasket.
Old May 14, 2006 | 12:54 AM
LSTEG96's Avatar
Default Re: Overheating with new rad (EK_GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK_GSR &raquo;</TD></TR><TR><TD CLASS="quote">i run 75 / 25 water to coolant respectively. also i have watter wetter. you should invest in that. it works... not a scam.
over flow can be related all the way from bad rad. cap to head gasket.</TD></TR></TABLE>
on our bikes we run nothing but water wetter and water... its simply the coolest. if u are in extreme cold, this is not an option.
Old May 14, 2006 | 05:03 AM
abnaasefmb's Avatar
Default Re: Overheating with new rad (LSTEG96)
I have the Fluidyne 1/2 size rad in an ef. I’m running a 1400 or 1500 cmf 14” fan I picked up from summit. I can sit in Hawaii traffic all day. Get a better fan. Pics are in my sig. Good luck.
D-meet07
Oct 20, 2006 12:42 PM
civic_boii
Sep 29, 2006 04:10 PM
Mr.Death
May 13, 2006 05:21 PM
coupon
Jul 21, 2005 10:42 AM
BigC-ivic
Oct 20, 2003 08:43 AM
