overheating issues?! turbo/ac
was wondering if anyone has had cooling issues with a turbo setup with ac. i almost think the rad is not getting enough airlfow since it has to go thru the intercooler and condenser before getting to the radiator. there is a puller 12inch flexalite fan. 1150 cfm. its an integra with an ac neukin manifold and using a civic aluminum radiator.
just wanted some input to help with airflow to radiator
The trick is to keep your intercooler and you radiator close together.
If not there is alot of tumble between the two and it cuts airflow off
dramaticly to your radiator at cruising speeds. 2 inches or less is what you want.
Also are you running a radiator shroud?
i did have a shroud on the mishimoto fan but the fan didnt flow worth the ****. so we put a larger better fan on there that flows better. there is a good space between the intercooler and the condenser. the condenser and rad are really close though like factory
try making a shroud first. Then if that doesnt work pull off your bumper
cover and get your ic, condenser, and radiator closer together.
Also If your turbo setup allows an integra radiator They cool almost
anything down and have room for 2 fans.
mine ran hot with mishi's fan as well, tried the shroud and not with great results.
(makes me think they came out with the triple core to fix this)
but i sourced a 13" 1300 CFM fan @xenocron.com and now my temps are 190 on a hot day.
hope that helps.
hope that helps.
any luck with this because I am in the same boat. I have same manifold with nuekin radiator and fan. Tried 170 degree thermostat and still runs hot.
The ability to run ac usualy forces the turbo to be in the way of a full size radiator. Placing them close together usualy is accomplished by making new supports and clearancing the bumper or core support. A sawzaw and die grinder are my preffered tools when doing this. If your overheating at idle a new fan would fix it with no moving necessary.
i have the same prob the thermostat creeps up on me on the high way but only when its hot out i ordered a daul core 2 inch thick1/2 size rad so i hope it dose the trick let you know
A.R
Jan 5, 2012 06:24 PM
