OT: 1992 Mustang, 331 stroker, t4/76, AEM EMS, low boost
Old Aug 21, 2006 | 05:10 AM
B18CXr's Avatar
Default OT: 1992 Mustang, 331 stroker, t4/76, AEM EMS, low boost
Nice change of pace in the shop this past Saturday
1992 Fox Body
331 (8.5:1)
AFR 185 heads
303E cam
Trick Flow upper/lower
Hellion Turbo kit (T76 upgrade)
83lb/hr
3.5 bar map
3.73 rear end
stock T5 (non-world class)
28 splines
9psi
Stock 2003 Z06 plot below for comparison.
Old Aug 21, 2006 | 05:26 AM
Mugencrxsir1's Avatar
Default Re: OT: 1992 Mustang, 331 stroker, t4/76, AEM EMS, low boost (B18CXr)
That's it, come on man, turn the boost up, you should be running 14psi at the lowest for a V8. Many honda's on here have more HP than that, take advantage of the extra 4 cyclinders, and turn the boost up. Still good power for a domestic at 9psi, if you run 16psi-20psi you should be well over 600hp, and with a 76mm turbo on the 331, it's not even being strand/used yet.
Old Aug 21, 2006 | 06:02 AM
quicksilver1689's Avatar
i ♥ snails
for real hahah stock bottom end b16's and gsr's have thrown down higher hp numbers! haha just joshin
Old Aug 21, 2006 | 06:04 AM
MidShipCivic's Avatar
It's odd how you went domestic talk on the displacement and injector size .
Old Aug 21, 2006 | 06:29 AM
R@mon's Avatar
Default Re: (MidShipCivic)
if its a stock block im sure he aint gunna go much higher than it is now. I see its a 331 but i mean the actual block itself.
Old Aug 21, 2006 | 06:41 AM
Finland's Avatar
Default Re: OT: 1992 Mustang, 331 stroker, t4/76, AEM EMS, low boost (Mugencrxsir1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugencrxsir1 &raquo;</TD></TR><TR><TD CLASS="quote">That's it, come on man, turn the boost up, you should be running 14psi at the lowest for a V8. Many honda's on here have more HP than that, take advantage of the extra 4 cyclinders, and turn the boost up. Still good power for a domestic at 9psi, if you run 16psi-20psi you should be well over 600hp, and with a 76mm turbo on the 331, it's not even being strand/used yet. </TD></TR></TABLE>
maybe he's after more than just peak HP..it's making 250 wtq barely off idle...and the torque 'curve' if you want to call it that looks like a ******* square wave..something us honda guys will never enjoy
Old Aug 21, 2006 | 07:14 AM
HT Chaplain's Avatar
Loved
Default Re: OT: 1992 Mustang, 331 stroker, t4/76, AEM EMS, low boost (Mr. Helsinki)
stock ZO6 has only 314 at the wheels? Whats the new ones have?
Old Aug 21, 2006 | 07:56 AM
david@didrace.com's Avatar
Default Re: OT: 1992 Mustang, 331 stroker, t4/76, AEM EMS, low boost (HT Chaplain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HT Chaplain &raquo;</TD></TR><TR><TD CLASS="quote">stock ZO6 has only 314 at the wheels? Whats the new ones have?</TD></TR></TABLE>
Only 314...
2003 Z06 = 405 @ the crank minus 20% drivetrain loss for manual transmission ~ 324 RWHP. But that depends on the specific vehicle and weather that day. We've dyno'd stock Z06's which range from 297 RWHP to 327 RWHP on our Mustang Dyno (P1Auto's dyno is a Mustang too, so it'll read slightly lower than a DynoJet).
The new C6 Z06's easily hit 420 RWHP with an advertised HP of 505 at the crank.
Old Aug 21, 2006 | 08:13 AM
Tony the Tiger's Avatar
Default Re: OT: 1992 Mustang, 331 stroker, t4/76, AEM EMS, low boost (backpurge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by backpurge &raquo;</TD></TR><TR><TD CLASS="quote">
Only 314...
The new C6 Z06's easily hit 420 RWHP with an advertised HP of 505 at the crank.</TD></TR></TABLE>
Those numbers are really low... I always thought the C5 Z06's put down close to 340-350 WHP considering that the LS1/LS6 tech handbook shows several LS6's baseline numbers being in that range. DynoJet numbers mostly.
20% driveline loss for manual is crazy... My Camry's auto loses about 22-24%... These Mustang dyno's read exceptionally low; hard to go by any dyno numbers these days except for before & after comparison purposes.
Old Aug 21, 2006 | 08:31 AM
Unsivil_audio's Avatar
Default Re: OT: 1992 Mustang, 331 stroker, t4/76, AEM EMS, low boost (Tony the Tiger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tony the Tiger &raquo;</TD></TR><TR><TD CLASS="quote">Those numbers are really low... I always thought the C5 Z06's put down close to 340-350 WHP considering that the LS1/LS6 tech handbook shows several LS6's baseline numbers being in that range. DynoJet numbers mostly.
20% driveline loss for manual is crazy... My Camry's auto loses about 22-24%... These Mustang dyno's read exceptionally low; hard to go by any dyno numbers these days except for before & after comparison purposes. </TD></TR></TABLE>
Really, I dont think so. Thats about right. My friends LS1 trans am dynoed 270whp at our elevation (3.5k) in stock form, with a few mods 307whp, which included, K&N, removed cats, WS6 throttle body, retuned ecu. I'm pretty sure that was on a mustang dyno too. Granted it was an auto too, but there are also alot more drivetrain components on a rwd; drive shaft, u-joints, rear end, then axles. I still thought it was 17% or less.
Old Aug 21, 2006 | 09:13 AM
stackz's Avatar
at the jetties fishin'
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr &raquo;</TD></TR><TR><TD CLASS="quote">Nice change of pace in the shop this past Saturday
1992 Fox Body
331 (8.5:1)
AFR 185 heads
303E cam
83lb/hr
3.5 bar map
3.73 rear end
28 splines
9psi
whats his timing like?? thats a little low for a 331 with a hellion kit.
is it a stock block with a stroke kit or like a D.S.S. shortie??
I'm interested in knowing how long that nonWC t5 is going to last behind that engine, those things suck even worse than WC t5's.
Old Aug 21, 2006 | 09:44 AM
alpha's Avatar
Looks good. Has the car been on the scales?
Old Aug 21, 2006 | 10:27 AM
boosted94cx's Avatar
* B A N N E D *
i'm just waiting for the follow up post of how his block split down the middle.
keeping it under 6k is smart...but, that's just way too much on a non-mexican block.
lots of power left in it though...shitty e-cam is killing him. even an f-cam would be better...... and trickflow upper and lower...even if it's the r-box its crap....spyder or similar would be awesome to see on there...and they're cheap....supervictor and intakeelbows.com elbow and you're set.
Old Aug 21, 2006 | 12:02 PM
Mike D's Avatar
Default Re: (boosted94cx)
mustang dyno people, not a dynojet.
Remember this.
Old Aug 21, 2006 | 12:10 PM
Kelly.'s Avatar
I've quit using this account
Default Re: (R@mon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R@mon &raquo;</TD></TR><TR><TD CLASS="quote">if its a stock block im sure he aint gunna go much higher than it is now. I see its a 331 but i mean the actual block itself. </TD></TR></TABLE>
i hear the stock blocks are good to ~700-750.
i am currently looking for a fox body, or a efi lst/lt1 to boost.
good to see im not the only one on HT that like turbo v8 enough to build one
Old Aug 21, 2006 | 01:12 PM
* B A N N E D *
Default Re: (Kelly.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kelly. &raquo;</TD></TR><TR><TD CLASS="quote">i hear the stock blocks are good to ~700-750.
good to see im not the only one on HT that like turbo v8 enough to build one </TD></TR></TABLE>
wow...um...no.. a stock 302, non-mexican roller is good for about 500whp...in small spurts...below 6000rpm. now, a mexican 302 might be good for around that...but not in large doses...although some have done it and stuck, but...it's just a fine line between cracked block and not.
if you do a fox body, do a 351w based engine, or an aftermarket block....or a bb. 351w based engines are cheap as hell to build (what i have) and you can get upwards of 450ci out of them. right now i'm going to start building up a 433w with a prosystems carb (only the best) on a vic. with some good aussie heads that are worked and a big shot on top with a c4/stall/brake. i'll be running mid 9's for the price it cost a honda to break into the 11's. and will still get 20+mpg
Old Aug 21, 2006 | 01:24 PM
michael O's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted94cx &raquo;</TD></TR><TR><TD CLASS="quote">if you do a fox body, do a 351w based engine, or an aftermarket block....or a bb. 351w based engines are cheap as hell to build (what i have) and you can get upwards of 450ci out of them. right now i'm going to start building up a 433w with a prosystems carb (only the best) on a vic. with some good aussie heads that are worked and a big shot on top with a c4/stall/brake. i'll be running mid 9's for the price it cost a honda to break into the 11's. and will still get 20+mpg</TD></TR></TABLE>
I want to do the same thing. except it would be easier to smog a honda.
Old Aug 21, 2006 | 04:34 PM
JDogg's Avatar
Default Re: (michaelOlson)
mustangs are fun to tune... i havent got to do a turbo stang yet, just a few big vortec blown mustangs. ****, 650 on pump shouldnt be a problem for that setup
Old Aug 21, 2006 | 04:39 PM
Kelly.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted94cx &raquo;</TD></TR><TR><TD CLASS="quote">wow...um...no.. a stock 302, non-mexican roller is good for about 500whp...in small spurts...below 6000rpm. now, a mexican 302 might be good for around that...but not in large doses...although some have done it and stuck, but...it's just a fine line between cracked block and not.
thanks for the info
i want to run 10s on street tires (M&H DOT bias ply )
im not brand loyal so ill take whatever chasis i can get my hands on cheap.
good luck with your car,
id like to see a video when it does run
Old Aug 21, 2006 | 04:49 PM
h22 civic's Avatar
a4block it!!!!!dynamic c4 also or at least a tremmec
Old Aug 21, 2006 | 06:33 PM
* B A N N E D *
tremec's are cool and all...but expensive. a t56 alone won't cut it with the 10spline input...at all. it couldn't even handle 618whp for us. you'll have to go viper spect t56 with a 26spline and steel forks.....or...tko600 or a modded tko900 would be nice...but, you'll still be giving up so much over a nice brake'd c4. you can get a c4 and 8" or so for fairly cheap
and 10's on radials can be done with a stock block, no problem. but.......go 351w and shoot for 9's on radials...also, not much of a problem.
90/10, 50/50, sfc, lowers and uppers, tq box bracing, and a few other small suspension things...and a mild 351 build will easily get you 10's on pump
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by michaelOlson &raquo;</TD></TR><TR><TD CLASS="quote">I want to do the same thing. except it would be easier to smog a honda. </TD></TR></TABLE>
buy a fox body.......then you have no smog worries.
Old Aug 21, 2006 | 09:29 PM
HiProfile's Avatar
One day I'm going to inject & turbo my 67 firebird, numbers like this would be fun. I know my mom's 02 WS6 is a blast to drive, so a boosted oldskool muscle car would be ****. Eventually I want to do some FI on a v8 just for fun.
I know I should poke my head outside of HT for this, but what sort of ecu mods do you do for a moostang, or does a larger MAF do the trick? The only one I know much about is boostang w/megasquirt.
btw your pix load like old people expletive
Old Aug 22, 2006 | 12:33 AM
T.J.'s Avatar
Default Re: (HiProfile)
Nice work Jack, im sure Tony was going nuts over this one.
Old Aug 22, 2006 | 03:28 AM
stackz's Avatar
Community Builder
bah, the only aussie heads worth a **** are the aussie cleveland heads, you building a clevor outta that w?
I've seen several non-texmex low nickel production 302 blocks in the mid 600's. The blocks can handle it if prepped right, just dont shoot gobs of nitrous at the same time. If I remember correctly that's what that one guy was doing exactly in those famous pics of his block split completely in half.
