OMG!
Old Jul 10, 2001 | 05:48 PM
Ray's Avatar
Ray
New User
Default OMG!
HELP!
Was reprograming my Boost Controller, on 3rd gear reached 6300rpm at only 5psi boost and BAM, Sudden power loss, tons of smoke out the back of my car(too shocked to remember the color), engine shuts down while im driving. I limp over to a parking lot and pop my hood. The upper radiator hose is disconnected coolant splash all over my engine only from the hose, no leaking from the engine. After 10 minutes I start the engine again and vaccum idle is at 15psi with white smoke coming out my exhaust. I attempt the 3 mile drive home, car is overheating and barely driveable. Seems like my headgasket blew but only at 5psi? I did a compession test(B18b with 9.1 pistons) a few weeks ago which read 180/175/165/185.
What do you guys think? Thanks in advance
Old Jul 10, 2001 | 05:51 PM
b18bturbo's Avatar
Default Re: OMG! (Ray)
flus the coolant. drain the oil recheck everything retorque the head gasket and then check again for coolant mixed with the oil.
Old Jul 10, 2001 | 05:57 PM
Ray's Avatar
Ray
New User
Default Re: OMG! (b18bturbo)
You think the headgasket doesnt need to be replaced?
Old Jul 10, 2001 | 06:03 PM
b18bturbo's Avatar
i would check your oil drain it see for water mixed with he oil if it is then replace it. but i think you jsut blew the hose off
Old Jul 10, 2001 | 06:15 PM
Ray's Avatar
Ray
New User
After I put the hose back on. I tried driving it home it kept overheating and white smoke kept coming out my exhaust.
Old Jul 10, 2001 | 06:18 PM
b18bturbo's Avatar
just drain the oil and see what you are burning in there its pretty simple thing to do. you should white mixture with the oil looks like brown stuff.
Old Jul 10, 2001 | 06:23 PM
LsTurbo91's Avatar
Damn Exact same thing happened to my old motor. I was running my friend's eclipse going on 5th gear. Then bam all i see is white smoke. The upper radiator hose blew too. white smoke in the tail pipe. Is there milky oil that came out of the breather on the valve cover. I thought I blew my headgasket. I ended up cracking a cylinder sleeve #2. Damn good luck.
[Modified by 9psiLsT, 7:25 PM 7/10/2001]
Old Jul 10, 2001 | 07:46 PM
Ray's Avatar
Ray
New User
Default Re: OMG! (9psiLsT)
I just drained my oil it's a little brown. So what does that mean?
Old Jul 10, 2001 | 07:56 PM
TurboInteg95's Avatar
I'm thinking it might be headgasket. maybe you should get some head studs while you're replacing it.
Old Jul 10, 2001 | 08:19 PM
Ray's Avatar
Ray
New User
Default Re: OMG! (TurboInteg95)
I was only running 5psi when it happened. Could it be my piston rings cause my compression test didnt look too good.
Old Jul 10, 2001 | 09:12 PM
LsTurbo91's Avatar
are they all low on all cylinders ? might be the headgasket then.
Old Jul 10, 2001 | 09:20 PM
Ray's Avatar
Ray
New User
180/175/165/185 When i did this the car wasnt warmed up but I dunno how much that affects it.
Old Jul 10, 2001 | 09:23 PM
LsTurbo91's Avatar
thats not low. Is it still smoking?
Old Jul 10, 2001 | 10:13 PM
Ray's Avatar
Ray
New User
I'll take the head off tomarrow. My idle vaccum is only 15psi I'm just hoping it's only a head gasket. I dunno what damage 5psi can do. Hope it's not the piston.
Old Jul 11, 2001 | 08:25 AM
madslackin's Avatar
Hey Ray,
How was the car tuned? You keep making it sound like "only 5psi" should never do any damage. If it's not tuned right that's very feasible...
Justin
Old Jul 11, 2001 | 09:47 AM
Ray's Avatar
Ray
New User
Default Re: OMG! (madslackin)
I dont have a compression tester right now. The compression numbers I stated were before this happened. Tuning-Wise im running a DRAG-Like fuel setup. FMU, NOS-inline pump and ignition retarded 1 degree.
Old Jul 11, 2001 | 11:06 AM
VaporTrail's Avatar
New User
There's your problem. Your ignition timing should be around 8-10 degrees, not one degree retarded from stock. Or, did you mean retard one degree per pound of boost?
Old Jul 11, 2001 | 02:22 PM
Ray's Avatar
Ray
New User
Default Re: OMG! (VaporTrail)
So I should 8-10degrees? Man thats alot. I remember people posting they retard only 1-2.
[Modified by Ray, 11:29 PM 7/11/2001]
Old Jul 11, 2001 | 02:24 PM
LsTurbo91's Avatar
I don't think it matters at this point. Open the head and take a look.
Old Jul 15, 2001 | 07:42 PM
Ray's Avatar
Ray
New User
Default Re: OMG! (Ray)Update*
Been Busy, but I pull the exhaust manifold off and poured water in the radiator and it came out my #4 exhaust. Looked kinda funny actually. I dunno what caused the gasket to go maybe overheating but the water temp was fine the old head gasket was a cheap aftermarket one so maybe. My oil is fine nothing mixed. I'm certain it's the head gasket now so im gonna bring it to a machine shop to check it out and likely resurface it. What else should I replace with the head off? I bought a Honda factory Headgasket. Anything else?
I bought some Skunk2 gears(they were half price) hopefully they dont just look good.
Old Jul 15, 2001 | 08:42 PM
Rob03Pro5's Avatar
Default Re: OMG! (Ray)Update* (Ray)
While you have the head off, get some ARP studs.. that's just my preference, although there is a flip side.. If you happen to detonate again, the ARP studs might hold your head down so tight that more damage can be done to your head while detonating, instead of just letting the head pop up and not take on all the force.
GWS372790
Aug 22, 2011 03:37 PM
FEAR6655
May 13, 2011 01:50 AM
cristegra09
Engine Management and Tuning
May 14, 2009 12:33 PM
Racermech
Jan 19, 2007 07:30 AM
dragon659
Sep 29, 2003 04:39 PM
