Ok Turbo Setup?
Old Apr 5, 2005 | 04:49 PM
wappid's Avatar
Default Ok Turbo Setup?
I'm putting my turbo in, in a few weeks just checking if I have missed anything? Also any comments welcome
Stock B18C
Subaru VF24 STi Rollerberring Turbo (inlet dia 46.7 A/R .63) Internal Wastegate
Custom Top Mount Manifiold
2.5 inch D/P + Full 2.5 exhaust
600mm x 300mm x 76mm Intercooler
VTi Civic Radiator (will upgrade when turbo is running)
450cc VR4 Injectors + Resistor Box
Hondata Stage 4B
HD Clutch
Thats all I think??? Im looking at getting around 200-250hp eventually. Then build the engine Do you think my goals are achievable with this setup?
Old Apr 5, 2005 | 05:37 PM
Evanmb44's Avatar
Default Re: Ok Turbo Setup? (wappid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wappid &raquo;</TD></TR><TR><TD CLASS="quote">I'm putting my turbo in, in a few weeks just checking if I have missed anything? Also any comments welcome
Stock B18C
Hondata Stage 4B
HD Clutch
Thats all I think??? Im looking at getting around 200-250hp eventually. Then build the engine Do you think my goals are achievable with this setup?</TD></TR></TABLE>
blow off valve
fuel pump
intercooler piping
oil lines, hose clamps, connectors
gauges
Old Apr 5, 2005 | 07:04 PM
wappid's Avatar
Default Re: Ok Turbo Setup? (Turboaddict)
I knew I forgot something.
I have also:
Mitsi Evo 3 Fuel Pump
GFB Bov
Piping + Connectors
Braided Oil and Water Lines
Boost and Oil Pressure Gauges
Old Apr 5, 2005 | 07:07 PM
dustin's Avatar
Sounds like you are good to go.
Old Apr 5, 2005 | 08:13 PM
wappid's Avatar
Default Re: Ok Turbo Setup? (dustin)
Are my HP goals attainable with this setup? I know there is a few things that I need to upgrade in the long run. But will this do for now?
the jdmchop
Jan 26, 2013 09:47 AM
JDMroyEG5turbo
May 1, 2006 09:12 AM
Charlie Moua
Oct 1, 2004 10:59 AM
shawn_crx
Nov 3, 2003 07:46 AM
sohcvtec1995
Sep 16, 2003 12:05 PM
