ok boost junkies, need advice with adapters...
Old Apr 1, 2013 | 02:50 AM
rayBans's Avatar
Default ok boost junkies, need advice with adapters...
To the point, my ramhorn cracked and i purchased a blueridge ramhorn for a decent price. My 35r is t4 flanged and the manifold is t3. I've never used adapters before so those guys that have...which do you recommend?? i see theres 2 types, plate style ( with sunken bolts) and the sandwich type (why is angled better)??
I have a full race downpipe and don't want to cut anything so please consider that while expressing your comments
Thanks
Old Apr 1, 2013 | 04:07 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: ok boost junkies, need advice with adapters...
The clocking/orientation desired would be the first thing to look at. If you are concerned by modification, then you should purchase the one that keeps the original clocking of the turbine housing. The "plate style" would offer minimal interferance as it is typically the thinnest design. Unless you can obtain exact measurements and angles, I suggest purchasing both and seeing which one will work better for you. You can always sell the unneeded one.
Old Apr 1, 2013 | 09:04 AM
rayBans's Avatar
^ thanks man...the clocking / placement of the turbo is nearly identical as the previous as both manifold are ramhorns. plate Adapters seems more durable as its just one single piece in contrast to the sandwich type consisting of multiple plates welded together with poor design and air flow.
Old Apr 1, 2013 | 05:41 PM
crvtectim's Avatar
I just cut the t3 flange off and welded the t3-t4 adapter plate onto the mani. My turbo sits low, so just bolting the adapter on would have caused the turbo to sit even lower, creating oil return line issues. Something to consider since you don't want to hack up your downpipe.
0ptimus prime
Feb 24, 2005 07:25 AM
0ptimus prime
Welding / Fabrication
Feb 23, 2005 05:56 PM
VTgringo
Jul 26, 2003 12:59 PM
paulzy
Jul 31, 2001 08:31 PM
