Oil Restrictor ?
Old May 28, 2003 | 08:28 AM
13lude's Avatar
Default Oil Restrictor ?
I have a 93 turbo lude that smokes somthin fierce until the first bar of temp comes on , also a little oil in charge lines . I have done the search and it sounds like once the car is warmed up the oil pressure drops {no more smoke} .I know I need a rebuild that is on the way. I am currently runnin a -4 oil feed line , Is there a way to reduce down to like -3 an without changing my feed line? What have you guys done? Thanks
Old May 28, 2003 | 09:26 AM
TEAMGENDAI's Avatar
Default Re: Oil Restrictor ? (13lude)
yup they sell restrictors for that. also is your return line kinked or tooo long?? make sure your return is a -12 or -10. good luck
Old May 28, 2003 | 09:29 AM
BROOD's Avatar
I'd check these things first; crankcase pressure and any blockage in the oil drain line.
Then I'd move to a restrictor method. The only thing that worries me about restrictors is the fact that a very small oil contaminant could block the restrictor orifice and block oil flow to the turbo...and you would not know it until it was too late.
Good luck throuble shooting the problem
Old May 28, 2003 | 11:07 AM
13lude's Avatar
Default Re: Oil Restrictor ? (SLPR)
I have a -10 drain line pretty much a straight shot down to the oil pan{drain up high on pan}I think it is too much oil pressure because once it is warm it will not smoke . It will only smoke when cold . I read that when the engine is cold the oil pressure is higher than when it is warm.
Old May 28, 2003 | 11:09 AM
13lude's Avatar
Where can I get restrictors without cahnging my line?
Old May 28, 2003 | 12:24 PM
BROOD's Avatar
Default Re: (13lude)
There was a brass 4AN to 1/8"NPT restrictor fitting that was perfect for what you want. But I can't find the dang part number on the NOS website. I'm pretty sure it is a NOS part.
**it was an autometer part**
Modified by BROOD at 7:08 AM 11/5/2003
Dre90
Apr 20, 2010 04:11 PM
Ad4mGSR
Jul 23, 2004 01:15 PM
nsxblueteg
Jun 10, 2003 11:08 AM
b18cya
Feb 19, 2003 10:50 PM
slingshotsi
Sep 9, 2001 06:11 PM
