Oil pump Question B18c1
Taken from an older post
ITRs weren't offered in 1992-95. That $128.44 is for older VTEC engines. The newer ones use a different part number.
1996-01 Integra Oil Pump Kit: $93.22
15100-P72-A01 PUMP ASSY., OIL
the reason i wanted a confirmation was that there is a OBD1 P72 and a OBD2 P72 correct? just dont know weather they had different oil pumps or if it even matters at all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j-D-m »</TD></TR><TR><TD CLASS="quote">the reason i wanted a confirmation was that there is a OBD1 P72 and a OBD2 P72 correct? just dont know weather they had different oil pumps or if it even matters at all.</TD></TR></TABLE> doesnt matter at all... same oil pumps either way..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmacaalay »</TD></TR><TR><TD CLASS="quote"> doesnt matter at all... same oil pumps either way..</TD></TR></TABLE>
yes and no.
obd2 pumps will bolt up and work, but the lower timming cover will not fit because of the CKF provisions. i have an ITR pump on my obd1 b16, but also did an ITR lower timming cover. so yes it will work, and no your lower cover will not fit.
yes and no.
i was under the impression the Obd2 oil pumps worked and flowed alot better? i just said screw it and used my obd1 b16 oil pump for my LS Vtec setup... works great, and have like 70 psi at WOT and like under 20 at idle...
and no, my timing cover didnt fit PERFECT... but it fit well enough with some patience
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg »</TD></TR><TR><TD CLASS="quote">i was under the impression the Obd2 oil pumps worked and flowed alot better? </TD></TR></TABLE>
Why though
Why though
not 100% sure, but when i was asking about it, people told me that they changed them in 96 and all b18s were using the Type R pump... but only from 96 up, so obd2
street_ride14
Sep 25, 2008 04:27 PM
