Oil Pressure
I have a turbo built d16z6 if it matters. But I've noticed my oil pressure has dropped over the last month or so. Not to sure if its the summer heat affecting it or what. So is it normal that i'm at 3k (forgot the speed but i think 65) and my oil pressure is at 24-26 psi? I heard about the rule of thumb that is 10psi per 1,000 rpm but I've noticed im 4psi shy from it. When warmed up i'm at idle it's 9psi and a cold start i start at 60psi Is my oil pump going bad? Im currently using royal purple 10w30 but do i need to move it up to 10w40? Or should i get a new better or even better is this normal during the summer weather? I'm driving down to florida within a month so I would like to figure out all this before the drive.
How old is the oil pump? I'd look at this article regarding your oil pump and other tips/tricks for your D-series build, and see if you and your installer are following these. The 1st thing mentioned is the oil pump. There's always been an efficiency problem with those especially for turbo D-series that needs to be addressed
The Old One - Energy Dynamics : Articles
I can vouch for high oil consumption with Mobil 1, it's what we pumped at a job I had a couple of years back so I was using it and could not figure out why my oil consumption was so bad. Then switched to any other brand and my consumption was cut in half. I was trying Mobil 1's extended performance so I could go 20,000 Kilometers between changes thinking I'd save money in the long run, not so much. Went through a second 5 quart jug before I hit 10,000 Kilometers and dumped the oil to switch to generic conventional oil that actually went the 5K without issue.
If you are talking synthetic, I would avoid Mobil 1. Stuff burns off way to quick. In recent discussions with people who follow the oil research, the best synthetic is actually Pennzoil. Kinda funny being back in the day Pennzoil was considered crap oil and Mobil 1 was the top dog.... Guess that's not the way it is now a days.
Exactly. Condition 1 was to get the OEM pump. Condition 2 still needs to be done. The Endyn alternation needs to be performed.
On B/H/K, yes. on D-series, they get fickle. This porting is almost a necessity for those guys from my experience.
could potentially be an issue in the bottom end? also how are you measuring oil pressure? i had a gauge in my car at one point that was an electronic sending unit. thing read next to no oil pressure at idle, and was not accurate really at any rpm due to the multiple factors, but i think the solid mounts have a poor effect on the sending units with vibration and such. i switched to an auto meter mechanical with a steel braided line and its killer accurate. ide advise to at least check it with a mechanical gauge, even if its not permanent.
glad to hear problem was "fixed". i don't think that thicker oil and a thick stabilizer is a "repair" to a low oil pressure complaint. will work for now but you may consider actually sourcing the problem. if the motor was assembled with this heavier oil in mind, that is one thing. But if its a stock motor and your dropping oil pressure, just thicker oil is not a long term repair. in my opinion.
I just reread your original post. If you just started having issues that points to deeper concerns. Maybe wise to drop the pan and pull a cap and maybe check a bearing or 2. Maybe pull you oil filter and cut it open? Hate to see it get worse and really do more damage and cost more in the long run.
the autometer electric sending units are utter garbage. I went through i think 3 of them over a few years before i just went with a mechanical gauge.
when did the sohc's start to have or notice issues with the oil pumps? I had a stock block in '04 and a vitara build in '09 both on stock pumps and i dont remember there being much conversation on oil pump deficiencies...(im not saying dont do the endyn mod)
Damned eBay strikes again.
