oil in my catch can?
Old Jun 12, 2004 | 12:08 PM
B18C1CYA's Avatar
Default oil in my catch can?
i need some help i seam to get some oil in my catch can after a nice pull on boost, i dont burn oil and compression is good, i have a home made catch can and i elemanted the black box and used the honda nipples on the block. it just makes no sence to me , is there some thing diffrent between the endyne fittings and the normal honda ones? i need to figure this out it driving me crazzy
Old Jun 12, 2004 | 08:29 PM
johnmay19's Avatar
Default Re: oil in my catch can? (B18C1CYA)
It is fine to have some oil in the catch can. That is the whole purpose of the catch can. Without it the oil would end up in your intake.
Old Jun 12, 2004 | 08:36 PM
D@nnY's Avatar
Default Re: oil in my catch can? (johnmay19)
Yes the endyn ones are different. they have a small tube in the middle ..anti suction tube. The purpose of a oil catch can is to catch oil....
Old Jun 13, 2004 | 09:07 AM
B18C1CYA's Avatar
Default Re: oil in my catch can? (D@nnY)
well i will call larry on monday and get his setup thanks
Old Jun 13, 2004 | 09:14 AM
johnmay19's Avatar
His setup will do the same thing.
Old Jun 13, 2004 | 09:19 AM
TurboJesse
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnmay19 &raquo;</TD></TR><TR><TD CLASS="quote">His setup will do the same thing.</TD></TR></TABLE>
no it won't...
snailpoweredEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@nnY &raquo;</TD></TR><TR><TD CLASS="quote">The purpose of a oil catch can is to catch oil....</TD></TR></TABLE>
I can't really see how someone would think it would do anything other than that.
I mean c'mon "oil catch can"...the name says it all.
Old Jun 13, 2004 | 09:21 AM
B18C1CYA's Avatar
Default Re: oil in my catch can? (snailpoweredEK)
i have the stock honda nipples and they just let out to much oil, and this must be a problem or the endyn ones would not be diffrent, i know the can is to catch oil there is just alot of it.
Old Jun 13, 2004 | 09:22 AM
johnmay19's Avatar
Default Re: oil in my catch can? (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">
no it won't...</TD></TR></TABLE>
It will still get oil in the catch can, but yes it will drain back. So we can both be correct.
Old Jun 13, 2004 | 09:38 AM
B18C1CYA's Avatar
ok so the block fittings that endyn sells are not diffrent than the ones i bought from honda?
Old Jun 13, 2004 | 09:50 AM
TurboJesse
Guest
Posts: n/a
they are different, give me a few minutes, i will take pics of both to compare them
Old Jun 13, 2004 | 09:51 AM
B18C1CYA's Avatar
cool thank you
Old Jun 13, 2004 | 10:31 AM
TurboJesse
Guest
Posts: n/a
endyne is on left, oem is on right
Old Jun 13, 2004 | 10:36 AM
B18C1CYA's Avatar
i see thank you so it isnt as easy for the oil to get up the line, verey good thanks
00pr3lude
Feb 13, 2008 09:04 PM
ahron
Sep 9, 2007 06:59 PM
ThrowSomeDs
Oct 30, 2006 05:06 PM
spoonracer84eg
Jul 23, 2006 06:36 PM
Bense
19
May 19, 2006 05:44 PM
