oil leak at high boost
has anyone encountered oil smoking after spending time in high boost. I think its coming from the pan gasket and then being spread all over the undercarage of the car from wind and the driveshaft landing on the exhaust. Usually see at a stop. If it is the pan can someone suggest a tried and true method of sealing that for good. b18c1
I Took out the pcv vavle stuck a nipple in there and ran a 3/4 inch hose up and teed into a hose same size from the valve cover into the greddy catch can. Th eother port in the catch can is just vented to atmosphere through a breather.
BoostinTEG
Jul 3, 2011 01:23 PM
