oil inlet angle
Old Jun 28, 2010 | 10:04 AM
2slowIntegraLS's Avatar
Default oil inlet angle
I am having trouble getting my center housing of my journal bearing garrett turbo to fit at the usual 12 o clock for the inlet and 6 for the drain line. I have the inlet at a 25 degree angle from vertical. In other words if you were to start at vertical and move clock wise 25 degrees that is the angle that my inlet is at right now. Will this work? The drain is therefore at the same angle but facing downward. The drain is a -10an if that makes a difference.
Old Jun 29, 2010 | 04:57 PM
Default Re: oil inlet angle
Someone please help! I don't want to start it till I figure out if the angle is ok
Old Jun 29, 2010 | 05:03 PM
Casey's Avatar
its pressurized entering the chra. as long as the angle on the drain isnt restricted youll be fine
Old Jun 30, 2010 | 12:08 AM
DreTec's Avatar
The closer to 12 and 6 the better as you want the drain to work as best as possible, but as said above, as long as the drain isn't restricted then it should be ok. Got any pics of the drain?
Old Jun 30, 2010 | 01:33 AM
viper_boy403's Avatar
Mine is about that same angle and it has absolutely no issues
Old Jun 30, 2010 | 10:31 AM
Ok thanks. Ya I'll try and get some pics today and put them up.
84Riceeater
May 2, 2014 11:11 PM
WhiteEJCoupe
Honda S2000
Mar 2, 2012 09:10 AM
ExVtec
Mar 16, 2011 12:32 AM
30psi_gst
Jun 12, 2010 01:53 PM
Ray
Jan 1, 2002 03:44 PM
