Oil Grade
Old Apr 27, 2005 | 07:09 AM
Under_Pressure's Avatar
Default Oil Grade
What oil grade is recommended when using a turbo? I've always have used castrol syntec 10w 30, But now that aim going turbo it will heat up the oil more than it did before. What should I use? And is it still oil change every 3000 or now is it less? Also Miami weather is hot so take that into consideration.
Old Apr 27, 2005 | 08:30 AM
Seraph0's Avatar
Default Re: Oil Grade (92h22alude)
10W-30 is good. I would make the move to synthetic however. Mobile 1 or your choice. 3000 mile oil changes are fine.
Old Apr 27, 2005 | 08:34 AM
FOrSfEd's Avatar
Default Re: Oil Grade (MarkC)
Syntheic is not something u have to get, I use to use mobil 1 but it seem to burn to quickly. I switched to part synthetic 10w 30 and it has been running great with no oil burning since. PLus synthetic is so damn expensive you can get part synthetic for about half the money per quart.
Old Apr 27, 2005 | 09:48 AM
Default Re: Oil Grade (FOrSfEd)
So then it looks like ill just use the same oil as ive allways used castrol syntec 10w 30. the only thing I might do then is a oil cooler kit. cheap insurance. I cant wait to go turbo!
Old Apr 27, 2005 | 10:30 AM
FOrSfEd's Avatar
I wouldn't worry about an oil cooler unless you in a very high tempature and your oil temps sky rocket. Your oil needs to be at a certain temp for everything to work right.
Old Apr 27, 2005 | 11:01 AM
ok sounds good thanks for the help people
Old Apr 27, 2005 | 01:25 PM
Mr. Vapor's Avatar
ive been running Mobil 1 for 3 years now...is it safe to switch to a semi-syn blend?
Old Apr 27, 2005 | 01:41 PM
Turbowa's Avatar
Default Re: Oil Grade (Mr. Vapor)
If you've been running Mobile 1 then yes. You can switch to what ever oil you'd like. Semi-syn or a regular conventional.
ultimatecivictyper
Nov 7, 2006 07:08 PM
blkbeast
May 28, 2003 10:48 PM
97integraLST
Nov 11, 2001 05:57 AM
TypeR01-424
Aug 17, 2001 07:51 AM
