oil feed line question
Old Jan 25, 2002 | 12:37 AM
808eg6's Avatar
Default oil feed line question
to hook up the oil feed line in the stock oil pressure sensor location i will need a 1/8 bspt to 1/8 npt adapter then a 1/8 npt to 4an adapter. then from there i go to 1-2 feet of steel braided line to a tee to mount on the firewall. the tee has to consist of 2 4an mounts and one 1/8 bspt for the oil pressure sensor. then from their 3-4 feet of steel braided line for the line from the tee to the turbo. am i supposed to run 90 degree swivel on the end of the steel braided lines. let me know if i am correct because i will be purchasing these parts tommorow. thanks for the help
Old Jan 25, 2002 | 05:09 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: oil feed line question (808eg6)
http://home.cinci.rr.com/mistab0ne/P...esfittings.gif
Old Jan 25, 2002 | 07:19 AM
HXMan's Avatar
Default Re: oil feed line question (Mista Bone)
What kind of line is that in the illustration?
Old Jan 25, 2002 | 09:58 AM
RGAZ's Avatar
New User
Default Re: oil feed line question (HXMan)
nylon tubing.
I used Aeroquip steel braided AN4 for my setup.
Randy
Old Jan 25, 2002 | 10:13 AM
D-SPEED's Avatar
Default Re: oil feed line question (RGAZ)
i have tried looking on ANplumbing and bakerprecision....and i cant find any BSPT fittings....where are you guys getting yours ?
Old Jan 25, 2002 | 10:26 AM
bigTom's Avatar
Default Re: oil feed line question (D-SPEED)
how i would do it...
(a)1/8 npt to -4 (or -3 if u want) male/male
ss line to firewall
npt "t" fitting
plug the oil sender in one hole, and use 2 more of the npt fittings (a) on the other two holes... ont for the ss line... and then use another ss line to go to the turbo
Old Jan 25, 2002 | 10:31 AM
D-SPEED's Avatar
Default Re: oil feed line question (Tom)
NPT is the wrong threading though right ? i dont want to gnarl the threads on the block
Old Jan 25, 2002 | 10:32 AM
dustin's Avatar
it's BSPT but NPT worked for me.
Old Jan 25, 2002 | 11:47 AM
Turbo B16A SI's Avatar
I used a NPT fitting, The threads are slightly different, actually so similar that it is neglegant, Just use an aluminum fitting and you should be fine, I have no trouble at all with mine. I used all earls performance plumbing, -4. You can get everything you need from summit racking or anywhere for that matter. the actual threads in the block are tapered so everything works out just fine. finding a BSPT fitting can be done, actually you can find them in some cheap automotive oil pressure test kits, but I would say dont even bother
Old Jan 25, 2002 | 12:50 PM
RGAZ's Avatar
New User
BSPT is easily found at Autozone in theri gauge adapter kits. It is brass and works just fine.
They are British Standard Pipe Taper or British Standard Pipe - Parallel. Either will work for you. The port is 1/8"
Randy
Old Jan 25, 2002 | 12:51 PM
1sick4door's Avatar
Default Re: oil feed line question (Turbo B16A SI)
...i thought i understood what i was doing now after reading these post im kinda confused...or is what i copy n pasted correct for my d16z6 ??i purcahsed a used kit and it did not come with the tee or anything...somethign i found on someones how to install greddy kit
The next step is perhaps the simplest yet most frustrating portion of the install. It is the installation of the brass tee, to the engine block, and then connecting the oil sending unit and oil pressure line to it. There are a couple of straight unions that are 1/8 NPT. The inventory Greddy sends says there are 3 unions, but I had only 2 and only had use for 2. One of the unions is a brass colored and the other is silver. The brass colored one has a flanged end that is going to fit to the oil pressure line. I am not sure if Greddy sends the same color unions for all kits but make sure that the union with the flange is the one used to connect the oil line to the tee. .
Old Jan 25, 2002 | 01:48 PM
Xerxes's Avatar
New User
holy !@#$ that picture is the bomb! I wish i had seen it before! That is definitely the best illustration of this whole deal that i have ever seen.
[Modified by Xerxes, 10:50 PM 1/25/2002]
gooberguy31
Feb 25, 2009 12:09 PM
memorybox
Dec 6, 2006 03:14 PM
EKB18BPR3
Jun 28, 2005 07:47 PM
B18 CYA
Apr 21, 2004 04:34 PM
importboi22
Oct 15, 2003 07:46 PM
