Oil Feed from the front of the Block?
Has anyone run an oil feed to the turbo from the front of the block (next to the VTEC switch). I know most people run it from the oil pressure sending unit, but has anyone tried running it from the front of the block? Will it mess with VTEC on a B18C1?
Just trying to figure out a clean way to run the line without going around the block.
not that there is TOO much pressurein vtec BUT there is little to no pressure or volume when NOT in vtec, super bad idea, friend went thru 4 turbos doing this................in 6 weeks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge »</TD></TR><TR><TD CLASS="quote"> friend went thru 4 turbos doing this................in 6 weeks.</TD></TR></TABLE>
Nooo way someone is dumb enough to leave the feed there through the life of four turbos. . .
