Oil Cooler Size?
Old May 12, 2004 | 09:28 AM
PM-Performance's Avatar
Default Oil Cooler Size?
I have been looking into getting an Oil Temp gauge and an oil cooler very shortly. My oil temp seem like they are thru the roof. As a temp fix i put thicker oil in it, but ultimately i want to look at an oil cooler.
What would be a decent size cooler to run?
Also where are people mounting these things to keep things cool?
any pics are nice. I dont even think ihave seen how they hook up before. I have checked thru the archives and i really didnt get what i was looking for.
Old May 12, 2004 | 09:54 AM
FOrSfEd's Avatar
Default Re: Oil Cooler Size? (itr206)
I know the one that b&m sells works pretty well and I was going to run that one, but summit also sells a dual filter relocation kit that includes a oil cooler. And it's only like 129.
Old May 12, 2004 | 10:02 AM
Default Re: Oil Cooler Size? (FOrSfEd)
i dont care much for relocating the filter. i jsut want cooler temps.
Old May 12, 2004 | 10:18 AM
FOrSfEd's Avatar
Then I would say the b&m would be good. I was looking at the summit catalog and they sell many type of oil/trans Cooler same thing.
Old May 12, 2004 | 11:40 AM
mamaboy's Avatar
there's the b&m one, pwr, mocal, earls, fluidyne, greddy (which comes with a thermostat), and you can check your local autozone.
Old May 12, 2004 | 11:57 AM
Default Re: Oil Cooler Size? (mamaboy)
i might check autozone on the way home to see what these look like. i jsut wasnt sure if bigger is better.
Old May 12, 2004 | 12:13 PM
tthame1's Avatar
I'm running an 11 x 5.75" B&M cooler and it lowered my oil temps 20 degrees just by running the turbo feed line to it b/f going to the turbo.
Old May 12, 2004 | 12:22 PM
Default Re: Oil Cooler Size? (tthame1)
damn . is there any specific way to run them? can you still run the stock cooler with the external one? i need to get a temo gauge too. im wondering if i will need to get a sandwich plate.
Old May 12, 2004 | 02:06 PM
tthame1's Avatar
you won't need a sandwich plate if you run your oil feed line to the cooler and then from the cooler to the turbo
Old May 12, 2004 | 02:22 PM
macrosshn's Avatar
the son and the heir
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tthame1 &raquo;</TD></TR><TR><TD CLASS="quote">you won't need a sandwich plate if you run your oil feed line to the cooler and then from the cooler to the turbo</TD></TR></TABLE>
If you run it this way, will there be adequated pressure and oiling into the turbo? Also, by going this routh, you wouldn't have to tap the block for an oil source right?
Old May 12, 2004 | 02:24 PM
Turbo E's Avatar
i didnt like the B&M the filter kept unscrewing itself and i kept blowing o-rings on the adapter because they were machined improperly.
B&M stepped up and sent me a new adapter gratis, but I ended up selling the kit.
Robert Singleto
May 23, 2011 08:22 PM
titebast
Aug 29, 2004 10:47 AM
redlineintegra
Jun 10, 2004 03:00 PM
hardboiled egz
Nov 20, 2002 02:55 PM
SiRkid
Sep 22, 2002 03:26 PM
