Oil Consumption on Boost?
Old Jan 13, 2007 | 08:55 AM
sundownz's Avatar
Default Oil Consumption on Boost?
I just finished my catch can setup on the Civic and so far so good. Before the can I had went through up to 1 quart of oil in about 300 miles or so. With the can installed I have used around 1/10th of a quart in 300 miles -- meaning I should use a quart in about 3000 miles or so.
How does this compare to what you guys are seeing? Sounds pretty reasonable to me, but I am just wondering what everyone else uses on their boosted setup
I'm pretty excited to have the consumption down so much... I did not want to tear down the engine if I didn't have to. I've got 500cc injectors, ignition hardness for my e-manage, a 2.5" Down-Pipe, and perhaps even an intercooler coming in before I get my car re-tuned!
I'm hoping to see 150 - 175 WHP or so out of my setup. I saw ~115 WHP / ~120 Torque on the dyno with stock injectors, factory exhaust, no ingnition sub-harness, and no catch can setup. These numbers were seen at under 5k rpm since my factory injectors go static above that point... so I think I'm being realistic
Old Jan 13, 2007 | 07:40 PM
turtle-eg's Avatar
Default Re: Oil Consumption on Boost? (sundownz)
Can you explain why you're losing less oil with a catch can setup? If the motor burns oil, then it'll still burn oil with a catch can connected.
Old Jan 14, 2007 | 06:38 AM
sundownz's Avatar
Default Re: Oil Consumption on Boost? (turtle-eg)
Before the can I had a totally stock PCV system which, by my understanding, can cause oil to get pushed through the rings and burnt.
Old Jan 14, 2007 | 06:40 AM
DaveF's Avatar
the stock pcv system "sucks" oil vapors from the engine, and re-circulates it into the intake, which makes its way to the cyl, and is ecentialy burned during the combustion cycle.
Old Jan 14, 2007 | 06:52 AM
sundownz's Avatar
Default Re: Oil Consumption on Boost? (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">the stock pcv system "sucks" oil vapors from the engine, and re-circulates it into the intake, which makes its way to the cyl, and is ecentialy burned during the combustion cycle.</TD></TR></TABLE>
Right... I know what it is supposed to do in a normal car. Under boost the PCV valve can become closed, correct? This causes a pressure buildup and oil can go through the rings. That is unless I have been mislead by what I have read about crank case ventilation on boost.
Old Jan 14, 2007 | 08:57 AM
DaveF's Avatar
if your motor is **** you might be getting oil on you cyl's or you might just blow oil out the breather & not get it in the cyl's.
Old Jan 14, 2007 | 09:29 AM
sundownz's Avatar
Either way... oil consumption dropped dramatically after I ventilated the crank case properly. Car runs better overall and smoke is very little now.
superhatchbackbros
Aug 14, 2006 08:53 AM
SOHCArchangel
May 7, 2003 09:03 AM
