Oil Consumption?
Old Sep 21, 2003 | 02:32 PM
Excelerate's Avatar
Default Oil Consumption?
How much oil do you guys consume every 1000 miles? Quart or more? Im consuming over a quart every 1000. Honda says that 1 quart every 1000 is okay, but now that ive gone turbo then i consumer more... is this normal?
Old Sep 21, 2003 | 02:43 PM
vtec.dc2's Avatar
Default Re: Oil Consumption? (JPLockwood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JPLockwood &raquo;</TD></TR><TR><TD CLASS="quote">Honda says that 1 quart every 1000 is okay</TD></TR></TABLE>
not okay..
do a compression test (compression test may reveal for rings), leakdown (for valve seals?)..
oil would have to make its way through seals.. headgasket (any oil spills around engine bay), piston rings or valve seals..
some oil goes in catch can.. if you run that.. if you get much oil out of breather valve on valve cover.. then its probably rings.. i don't think you should get any oil out of there.. if anything very minor
odd sounds from engine? puffs of smoke from oil cap or breather valve? or blue smoke out exhaust?
are you loosing coolant?
check for all of these
Old Sep 21, 2003 | 06:03 PM
Excelerate's Avatar
any other ideas/opinions?
Old Sep 21, 2003 | 06:17 PM
grndcont's Avatar
sometimes old turbos that are going south leak oil into the snails. look for oil in your charge pipe.
Old Sep 21, 2003 | 06:26 PM
shermanyang's Avatar
Default Re: (grndcont)
1 quart of oil every 1000 miles? i've never heard of this...and i think it's just honda's way of avoiding your problems. if that were the case...you'd only have 1 quart of oil left before every oil change
Old Sep 21, 2003 | 07:59 PM
kamaleon's Avatar
Default Re: (shermanyang)
1 quart of oil.. maybe for a highly modified engine lots of powa..
my engien didnt miss any oil at oil changes.. if so so minimal i couldnt tell..
after i boosted it consumed a bit of oil but not that drastic
somethign is wrong.. righs or valve seals as mentioned b4
Old Sep 21, 2003 | 08:04 PM
2k1 itr's Avatar
New User
Default Re: (kamaleon)
If you want my honest opinion you have a serious problem. You should not burn over 1 quart of oil every 1000 miles. Whoever told you that is lieing. Do a compression and leak down test. There is definetly a problem somewhere.
Old Sep 21, 2003 | 09:26 PM
Foozball26's Avatar
Default Re: (2k1 itr)
check for physical leaking from any fittings or the turbo itself
orioncivic
Oct 10, 2008 02:00 PM
Jeff
Apr 30, 2005 04:01 PM
Jeff
Apr 18, 2005 06:23 AM
Accel Junky
Apr 28, 2003 02:18 PM
superR303
Apr 23, 2002 05:06 AM
