oil in the compressor inlet??
Old Feb 5, 2008 | 12:48 AM
riceball777's Avatar
Default oil in the compressor inlet??
i have oil in the compressor inlet. what does this mean??
Old Feb 5, 2008 | 01:12 AM
integlspwr2k's Avatar
Default Re: oil in the compressor inlet?? (riceball777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">i have oil in the compressor inlet. what does this mean??</TD></TR></TABLE>
oil is passing the seals which means your oil pressure is really high or your turbo is blown.
Old Feb 5, 2008 | 04:35 AM
sneakysneaky's Avatar
looks like its time for a rebuild for u. once those seals start leaking
they always seem to leak after that.
Old Feb 5, 2008 | 06:34 AM
TiAL's Avatar
Default Re: oil in the compressor inlet?? (sneakysneaky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sneakysneaky &raquo;</TD></TR><TR><TD CLASS="quote">looks like its time for a rebuild for u. once those seals start leaking
they always seem to leak after that.</TD></TR></TABLE>
and what seals are you refering to?
turbos don't have seals, reduce your oil pressure, the turbo is fine
Old Feb 5, 2008 | 07:17 AM
turbodano's Avatar
The reason the seal bore leaks after a turbo has had to much oil pressure for the size of the drain is:
When the oil can not return to the oil pan it fills the bearing housing up with oil and once it gets higher than the piston ring gap it flows out into the compressor cover and the turbine side of the turbo. Once the drain or oil pressure is fixed the left over oil on the turbine side turns into carbon and we all know carbon is very abrasive. The carbon on the turbine side around the piston ring grove wears the seal bore out as well as the piston ring grove. When this happens the piston ring wears and allows oil to pas by it and leak into the turbine housing. Thats what gives you that wonderful smoking problem at idle.
A simple fix for this to take the turbine housing off and remove the oil from the heat shield or to send the turbo to a repair shop for them to take it apart and do a thorough cleaning. It is much cheaper to do it this way then let it fail and pay big bucks later on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TiAL &raquo;</TD></TR><TR><TD CLASS="quote">
turbos don't have seals, reduce your oil pressure, the turbo is fine</TD></TR></TABLE>
Turbochargers don't have anything technically called a seal but they do have things that act as seals. They are called piston rings or carbon seals.
Old Feb 5, 2008 | 12:13 PM
TiAL's Avatar
Default Re: oil in the compressor inlet?? (turbodano)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbodano &raquo;</TD></TR><TR><TD CLASS="quote">
Turbochargers don't have anything technically called a seal but they do have things that act as seals. They are called piston rings or carbon seals. </TD></TR></TABLE>
they have gas seals (piston rings you are refering to)
and i havn't seen carbon seals since carburation was around
Old Feb 5, 2008 | 12:39 PM
turbodano's Avatar
Default Re: oil in the compressor inlet?? (TiAL)
and i havn't seen carbon seals since carburation was around </TD></TR></TABLE>
When looking at parts break downs of the turbochargers they are labeled as piston rings. It is listed that way in all the turbo material I have. I have the Garrett CD, Borg Warner CD, Mitsubishi CD, Holset CD. ......
Carbon seals are still used in late model apps also. Look at the twin turbo RX7.
Have you ever seen the carbon seal in the Rajay turbos. Talk about nasty old things. Good god.
I am not a big fan of the carbon seals they create to much drag on the rotating assy.
Old Feb 5, 2008 | 12:54 PM
CO_CReX's Avatar
Throw a restrictor on it and see if it stops
Old Feb 5, 2008 | 01:07 PM
turbodano's Avatar
Default Re: (CO_CReX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CO_CReX &raquo;</TD></TR><TR><TD CLASS="quote">Throw a restrictor on it and see if it stops</TD></TR></TABLE>
Carefully with saying that. Just sticking a restrictor in there without confirming the oil pressure that you have at the turbo may cause turbo failure. If your oil pressure is not too high it could be your drain.
Post some pics of your drain set up.
Old Feb 5, 2008 | 03:23 PM
D-Rizzle3's Avatar
I'm having the same problem on my setup and I haven't even hit boost yet..xs turbo, no restrictor
ender214
Feb 24, 2008 02:32 AM
EX-T
Jan 18, 2008 08:44 AM
done
Jul 27, 2004 08:10 AM
is3oo
Jun 6, 2004 06:49 AM
importboi22
May 1, 2004 11:11 PM
