Oil Catch Can /PCV Install Question
Old Feb 22, 2010 | 09:06 PM
accord99power's Avatar
Default Oil Catch Can /PCV Install Question
Bought the universal oil Catch can. Setup is in signature.
1)Is there anyway to hook up the 2nd port of the crankcase to tie into the line going to the input port of then Catch can? Basically the PCV Valve line and the 2nd port near the intake would both go into the one side of the catch can.
I bought a T and tried to install it into the same line however after installing i got loud screaching or taps from valve cover. Unistalled and it went away.
2) I modified the PCV and removed the inside of it, Should i use the OEM PCV Valve with the catch can or modified PCV straight through no restriction design?
Old Feb 23, 2010 | 10:26 AM
welfarepc's Avatar
Default Re: Oil Catch Can /PCV Install Question
take pics of what you have done so far.
i think you are pressurizing the block with boost.
Old Feb 23, 2010 | 11:27 AM
Picture 1 is for the first question
Picture 2 is for the 2nd question, Does it hurt anything gutting the pcv valve out wouldnt it move more pressure out of the Valve Cover?
Old Feb 24, 2010 | 07:16 AM
*Bump* please help updated with pics.
Old Feb 24, 2010 | 09:35 AM
NonovUrbizniz's Avatar
Loved
where does that blue hose come from? and is it also hooked upto the catchcan?
Old Feb 24, 2010 | 10:40 AM
welfarepc's Avatar
where are those hoses from your VC going? it looks like one goes to a sealed catch can? if that is the case, where does that blue hose go?
where does the other hose/steel tube go to?
as for gutting your PCV valve... it depends how you have your catch can setup. leaving it in tact should stop boost from entering your block, but that is when you need the vac on the block the most. the pressure from boost will close the pcv valve. factory turbo cars use a pcv valve but have an alternative vac source (pre turbo slash) that will help pull vac on the block when the charge piping is pressurized.
it really depends how you have your can setup.
Old Feb 24, 2010 | 04:43 PM
thanks for the reply guys, right now the steel braided Air hose connect PCV VALVE to INPUT of CATCH CAN. The BLUE hose connects from OUTPUT of CATCH CAN to INTAKE MANIFOLD.
The 2nd Port on the Valvecover to the left is connected to nothin OPEN air. But want to connect to the Steel Braided Hose Line going to Input of Catch Can.
Old Feb 24, 2010 | 04:45 PM
i was advised today by someone to keep the stock PCV valve on and not the gutted out one or it will pressurize the block if i use the gutted one. Sound right?
yes
Old Feb 25, 2010 | 04:17 PM
*bump*
Old Feb 26, 2010 | 05:34 AM
dpetro1's Avatar
im a bit confused on how you have the can setup now. what does the can even look like? is it sealed or does it have a filter on top? if its sealed then you really arent doing much to relieve crancase pressure unless you are doing a slash-cut intake or exhaust method to pull pressure out.
i think you should just do 2 lines off the valve cover to the can with a filter on top, remove the stock pcv system entirely. simple and effective
Old Feb 26, 2010 | 10:23 AM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
sounds right, but the stock honda PCV valve will also leak under boost. your best bet is to gut the honda PCV valve and get a valve from a turbo DSM. It is an in-line metal valve that will not leak under boost.
Old Feb 26, 2010 | 11:45 AM
welfarepc's Avatar
what have you done at the back of the block??
what you have going on right now will work alright. but it will introduce some oil vapor into your charge, which is not ideal in a high output setup.
best bet is to open vent, or run a slash cut into your exhaust.
FYI; these threads always turn out like **** because everyone and their mom has their own way of installing a catch can. just a heads up.
Old Feb 26, 2010 | 09:34 PM
Sealed with only 2 ports on top. im trying to run both ports into can but i got a bad sound when trying that method from motor. I "T" both vlave cover ports into the input of ctach can heres the setup.
Old Feb 26, 2010 | 09:39 PM
nothing to the back of block except for the turbo oil input line.
Old Feb 26, 2010 | 09:41 PM
ae you refeing to this http://www.dsmparts.com/customer/pro...&cat=87&page=1 ?
Old Feb 27, 2010 | 04:24 AM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
no, what you have there is an oil restrictor for the turbo feed line...
this is exactly what you need...
http://shop.advanceautoparts.com/web...1073941413___#
Old Feb 28, 2010 | 04:54 AM
Just wanna make sure i got this right. So i will be able to hookup both valve cover ports on 1 line going to the Catch can whenever i install this inline pcv valve?
Old Feb 28, 2010 | 09:43 AM
spawn_616's Avatar
i ran the pvc line to the tyre wall and the one from the valve covers also just run down,unless thats illegal in the states,RSA doesnt have much for laws
Old Feb 28, 2010 | 07:12 PM
rat city rex's Avatar
If you run it like the ms paint pic that is above, you will not be doing anything at all. If its a sealed catch can its dumb!!
Cap the port on your intake mani, Run your 2 ports off of your vc to a vented catch can and it would be better. But if it had a drain back to the oilpan, or the box on the back of your block, it would be best!
Old Feb 28, 2010 | 08:49 PM
DiMartino Fab's Avatar
I run my PCV valve and the port on my valve cover strait to a catch can with a filter. Works good for me. I get more water(condensation) than anything. Even with 230K and 12psi on my b16. I would def. cap the intake manifold port and not run it to the can.
Old Mar 1, 2010 | 05:17 AM
dpetro1's Avatar
you cannot run a vacuum line to the catch can. when you go into boost you are pressurizing the can. as stated above, this setup is not doing anything to relieve crankcase pressure
Old Mar 1, 2010 | 05:24 AM
kyden's Avatar
your setup right now is actually doing the opposite of what you want it to do. you're pressurizing the crankcase under boost.
Old Mar 4, 2010 | 09:17 PM
Much thanks to everyone,you guys kick ***! i am switching it back asap!
Old Mar 4, 2010 | 09:21 PM
So heres my idea cap off the IM, for the catch can drill a hole, weld a little bung, and attach a little filter yeah? nah?
