Oil
Old Jan 22, 2004 | 05:46 PM
shawn_crx's Avatar
Default Oil
Quick question, If I'm planning to rev the engine up to 9500 RPM. Do I need to upgrade my oil pump or leave it stock.
If upgrade what is my options?
Old Jan 22, 2004 | 06:03 PM
FOrSfEd's Avatar
Default Re: Oil (shawn_crx)
What kind of car and set up.
Old Jan 22, 2004 | 06:07 PM
rtype11's Avatar
if b series go type R pump, I have flow numbers versus GSR and LS pumps to prove. may also want to consider Pro drive ( or other company) oil pump gear.
Old Jan 22, 2004 | 07:15 PM
shawn_crx's Avatar
Default Re: Oil (rtype11)
B18B.
Type R pump.
On waterpump gear is diff. from the LS Gears?
If I do go with the GS-R pump, which Timing belts do I use?
Modified by shawn_crx at 10:57 PM 1/22/2004
Old Jan 22, 2004 | 07:44 PM
Flamenco-T's Avatar
it all depends on the water pump. Oil pump are the same since you can use your existing oil pump sprocket. If you are keeping your LS water pump, stick with LS timing belt, if you;re going with GS-R water pump, then go with GS-R belt.
stan
Old Jan 22, 2004 | 08:07 PM
15psi of fun's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtype11 &raquo;</TD></TR><TR><TD CLASS="quote">if b series go type R pump, I have flow numbers versus GSR and LS pumps to prove. may also want to consider Pro drive ( or other company) oil pump gear.</TD></TR></TABLE>
that do you mean have flow numbers versus GSR isn't the type r and gsr the same. At lest when i went to get my new oil pump i asked for a type r and they didn't have it so he looked up a gsr and it was the same part number.
Flamenco-T's Avatar
Default Re: Oil (EFrollingout)
Type R and GS-R are the same...same size and part number..
stan
Old Jan 22, 2004 | 08:09 PM
SiBirdie's Avatar
I heard stock oil pump gear sometime tend to break at high rpm or high power boosted motors ? is that true? I was consider using a ITR oil pump with the itr oil pump gear. I was wondering how much power can stock oil pump gear hold up ?
Old Jan 22, 2004 | 08:11 PM
shawn_crx's Avatar
Default Re: Oil (Flamenco-T)
So if I changed my waterpump to GSR, then I could use an GSR timing belt?
Some says that GSR are a little longer then LS timing belts?
mixed answers.
Old Jan 23, 2004 | 09:09 AM
shawn_crx's Avatar
up
Old Jan 23, 2004 | 11:29 AM
BROOD's Avatar
The GSR and ITR timing belts are slightly longer than the LS/B20 timing belts. The Vtec water pumps have a larger OD drive gear to slow down the impeller speeds and high engine rpm.
Match the timing belt to the water pump used.
Old Jan 23, 2004 | 11:51 AM
shawn_crx's Avatar
Default Re: Oil (BROOD)
So that slightly excess wouldn't cause any problems?
Old Jan 23, 2004 | 01:37 PM
Flamenco-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shawn_crx &raquo;</TD></TR><TR><TD CLASS="quote">So that slightly excess wouldn't cause any problems?</TD></TR></TABLE>
if you use the timing belt in correspondence to the water pump, then there's shouldn't be any excess after the tensioner tightenes it.
stan
Old Jan 23, 2004 | 03:33 PM
Lucky_Smurf's Avatar
Just my $.02 get and gsr/type r oil pump and send it to endyn. It's expensive but they bore it out and change the flow passages so you get better/more flow. I did that and it looks very nice. Cost for the work is 135.00.
Old Jan 24, 2004 | 07:32 PM
rtype11's Avatar
sorry my original post was poorly worded - R and GSR same versus LS as follows:
oil pump B18C1/C5 flow 71L /minute @ 7600rpm
B18A/B flow 50L/minute @ 6000rpm
water pump B18C1/C5 flow 140L /minute @ 7600rpm
B18A/B flow 140L/minute @ 6000rpm
hope that is clearer
Old Jan 25, 2004 | 12:34 AM
LBR92DA-T's Avatar
Default Re: Oil (Lucky_Smurf)
yea im getting mine bored out for better oil flow.. 135?! ****.. my machine shop doesnt tell me the price for all the work... but when i get the bill i hope my wallet doesnt run away...
deemy72
Jul 9, 2009 10:20 AM
Dkahn18
Mar 17, 2009 05:47 PM
KdF
Mar 10, 2009 05:36 PM
soon2bdropped
Jul 22, 2007 11:33 AM
VWkila
Jan 29, 2003 02:09 PM
