The Official help sam finish his kit thread
Old Jan 18, 2011 | 05:14 PM
$amGD3's Avatar
Swaggylicious
Default The Official help sam finish his kit thread
Hey everyone,
So I finally took the plunge today and bought a partial kit from a local forum.
Here's the rundown...
Cast log-style manifold (unknown brand) IF YOU KNOW WHAT BRAND MANIFOLD THIS IS, PLEASE POST, THANKS!
Garrett a/r .50(cold) a/r .63(hot)
Tial 38mm wastegate with "small blue" spring inside which their website claims 8.7lbs
Greddy BOV (unknown model) < How would I check for this?
IC piping (2 1/4" I.D) and an unknown brand intercooler
The Garrett is in decent shape, but I would feel safer to get it rebuilt. There is a bit of shaft play and the intake fins are rough. Where do you guys recommend I get it rebuilt? What price range do you guys think I'll be looking at?
I'm not even sure what model turbo this is. I'm guessing it's an t3/t4?(will post pics soon)
Fuel. What do you guys recommend? 440s? 550s? Will stock pump suffice?
Piping. Where can I get piping online? Bends, straights etc. My good friend will TIG all of it, so it doesnt have to come pre-welded
This will all be installed in my EM1 with the stock b16a2 and at all cost ac must be retained, with that said, will a 2.5" downpipe clear?
Anything else you guys would like to add, please feel free
Thanks!!
edit, pics
UPDATE 1
Picked up some RC 550s today, dropped it off at the turbo shop to get cleaned and flow tested.
Good and bad news for the turbo. Good news is the housings arent damaged, the bad news is someone before me that had the turbo had it rebuilt by a shoddy *** shop. Apparently the turbine wheel isn't even a garrett part, it's a knockoff. He'll give me estimates tomorrow
UPDATE 2
Bought the Walbro 255 and a whole bunch of turbo gaskets, downpipe flange and piping
Still waiting to hear from the turbo shop on the extent of the rebuild
UPDATE 3
Sent my ecu off to get chipped and get a basemap today
This turbo is kicking my ***. For some reason the last shop that did the rebuilt, gipped the **** out of the last owner and put a Master Power turbine wheel/shaft and exhaust housing.
Now my shop is trying to find a garrett shaft/turbine wheel that will fit this housing but no luck thus far.
He's also trying to find the rebuild parts from Master Power for plan B if he can't find find a garrett shaft that will fit.
UPDATE 4
Parts from Treadstone came in today!! Damn that was fast!
misc gaskets,flanges,Tial .5 bar wastegate spring
GUYS I NEED YOUR HELP
This is all the piping that came with my IC. IS THIS ENOUGH?? Do I need to buy any more piping?
Also the smaller 90 degree bend is 2.5" dia while the rest is 2.25" WTF, can I make this work? What should I scrap and keep?
IF worse comes to worse I have to buy a new turbo. Which of these is the best for the price?
Question is...which? Are these both AC friendly with the log?
Precision Turbo Entry Level 54mm T3/T4 480HP Super sale $599! (also avail in 57 and 60 trim and a/r avail in .48A/R, .63A/R, or .82
https://honda-tech.com/forums/forced-induction-49/precision-turbo-entry-level-54mm-59mm-t3-t4-430hp-600hp-super-sale-%24599-2835667/
or any of these?
466159-5004 – T3/T4, A/R .63 – 60 Trim $599
466159-5003 – T3/T4, A/R .63 – 57 Trim $599
466159-5005 – T3/T4, A/R .48 – 57 Trim $599
715583-5007 - T3-60-1, A/R .82 - $649
715583-5005 - T3-60-1, A/R .48 - $649
715583-5006 - T3-60-1, A/R .63 - $649
https://honda-tech.com/forums/forced-induction-49/garrett-turbo-great-pricing-same-day-shipping-many-models-2407170/
Old Jan 18, 2011 | 05:29 PM
LightningTeg's Avatar
Community Builder
Default Re: The Official help sam finish his kit thread
If the wheel is damaged it will most likely need to be replaced, just a warning.
Old Jan 18, 2011 | 05:43 PM
$amGD3's Avatar
Swaggylicious
yeah, I realized that. I just wanted to get an estimate to see if I should junk the turbo or if it's worth getting rebuilt
Old Jan 18, 2011 | 06:51 PM
Trojan Man's Avatar
No Sales Forums
From: Reading the Chronicles and Blowin Trees in Virginia
There is a place in Canada I recommend for rebuilding. Don't know the name but I should be able to find out.
Old Jan 18, 2011 | 06:52 PM
WeakSi's Avatar
You will have to most likely cut on the block some for the turbo to fit. Won't hurt anything just figured I would let you know. 440-550s would be fine I would go ahead and get a walboro to be on the safe side.
You can buy piping kits from company's like Treadstone which have pretty much everything you need to bolt it up.
Hope this helps, and good luck!
Old Jan 18, 2011 | 06:58 PM
$amGD3's Avatar
Swaggylicious
Thanks my em1 peeps!
Hopefully, the grinding on the block wont be too excessive
I'm checking out treadstone now
Old Jan 18, 2011 | 07:06 PM
siblues's Avatar
If you are looking for aluminum piping hit up Stan at fast turbo and tell him I sent you he is a real cool guys and he can get you the injectors and walbro too.I would get a bit bigger injectors because we always say we arent going to tiurn up the boost but we always do you can tune the injectors to run fine just get bigger ones so they will be one less part to purchase later.
Old Jan 18, 2011 | 07:08 PM
sc34dc4's Avatar
Your blow off valve is a greddy type S
Old Jan 18, 2011 | 07:21 PM
$amGD3's Avatar
Swaggylicious
Thanks! I hope it's a real Greddy.
I was pleasantly surprised to see that the Tial wastegate is authentic lol
$amGD3's Avatar
Swaggylicious
thanks!do they have a website?
Old Jan 18, 2011 | 10:03 PM
Gunmetal_B20_Hatch's Avatar
stock fuel pump is good up to 200-220whp. 440cc injectors will get you to about 350whp with 60psi fuel press.
Old Jan 18, 2011 | 10:10 PM
$amGD3's Avatar
Swaggylicious
So do you think 550s is overkill? Should I get a walbro 255 just to be safe?
Old Jan 19, 2011 | 12:04 AM
siblues's Avatar
I am going to tell you this if you are the type to switch cetups often or you will eventually want to make more power then buy bigger injectors and the walbro.They used to be a sponsor on here and I have been buying stuff from him for ten years.The website is fast-turbo.com you can search some of his old threads they are still on here but I would call him instead he will explain everything to you and he is a real cool guy not trying to just sell you a bunch of parts.
Old Jan 19, 2011 | 05:52 AM
$amGD3's Avatar
Swaggylicious
Im not one to switch setups often but I'll most likely upgrade to a 255 and 440s now just to save time in the long haul
Old Jan 19, 2011 | 05:53 AM
$amGD3's Avatar
Swaggylicious
Do you guys think 3-400 for a rebuild on this turbo is fair?
Old Jan 19, 2011 | 06:26 AM
ryguy2588's Avatar
It's a real greddy type s.
Old Jan 19, 2011 | 08:33 AM
skateboard_ej8's Avatar
im hench irl
Sweet, in for this.
Old Jan 19, 2011 | 09:12 AM
$amGD3's Avatar
Swaggylicious
Thanks guys
Trying to pick up some rc550s now
Just dropped off the turbo at the shop,hopefully its not it too bad of a condition to be rebuilt
Old Jan 19, 2011 | 01:41 PM
$amGD3's Avatar
Swaggylicious
ttt
Old Jan 19, 2011 | 04:30 PM
$amGD3's Avatar
Swaggylicious
update!
I'm thinking if the repair cost is more than $400, I'm just gonna junk it. There's a vendor on here that sells the same garrett turbo with the same specs for $599 shipped
what do you guys think?
Old Jan 19, 2011 | 06:17 PM
Community Builder
Get a new turbo.
Old Jan 19, 2011 | 06:20 PM
ryguy2588's Avatar
Originally Posted by LightningTeg
Get a new turbo.
X2
Try to part out the housings for some cash and get a new one.
Old Jan 19, 2011 | 07:37 PM
$amGD3's Avatar
Swaggylicious
Where can I sell those? Is there a market for it?
Old Jan 20, 2011 | 06:16 AM
blaze the chemi's Avatar
Try the market by putting it out there or search for one.
Man I miss boost. I think you have a good idea and setup. 550's and a walbro pump should be good to go. I was pushing 248whp @ 12psi through my greddy turbo with those injectors and stock pump.
Old Jan 20, 2011 | 07:20 AM
$amGD3's Avatar
Swaggylicious
They sell housings on ebay but i dont really see any used ones,i wouldnt even know how to sell them because i dont know what kind of housings i have
Thanks man, i just want everything to work well together,hopefully itll come together
