Oem or acl bearing
Old Nov 13, 2011 | 06:07 AM
spoolinvtec54's Avatar
Default Oem or acl bearing
I'm working on my b18b trying to figure what are the best bearings to use.
Old Nov 13, 2011 | 06:12 AM
TheShodan's Avatar
Moderator
Default Re: Oem or acl bearing
People will come on here to promote both. Both can work. I'm an OEM person, but you'll have advocates for ACL as well. So, this "poll" really won't help with your decision.
Old Nov 13, 2011 | 06:54 AM
rich7777's Avatar
Depends on your clearances
Old Nov 13, 2011 | 07:23 AM
igorka_91's Avatar
If the acls give you the clearances you need. run them. if the oem give the clearances you need. run them.
Old Nov 13, 2011 | 07:46 AM
I know that Honda oem bearings are color coated. But how can u tell what size on acl bearings.
Old Nov 13, 2011 | 09:02 AM
h2.4's Avatar
Measure them. But usually the ACl's are in the "green" range of honda's Oem bearings. Then you can get the "X" acl's that gives you .001" more clearance than the std's.
Old Nov 13, 2011 | 09:06 AM
I'm just wondering since I had it line bore for my main girdle.
golf-mk3
May 11, 2010 01:37 PM
Speed Infliction
May 1, 2006 07:24 PM
Takumi Fujiwara
97
Nov 18, 2005 11:54 AM
GSRCRXsi
14
Jul 11, 2005 07:09 PM
