Odyssey Battery and 2.2L
Old Feb 4, 2009 | 05:55 AM
JDMCRX's Avatar
Default Odyssey Battery and 2.2L
Curious anyof you guys use the odyssey small battery on there H22 or F22.
IM curious before i spend the day making a battery tray and buying this battery the odyssey extreme racing 15,30 or 40 ?
Old Feb 4, 2009 | 06:39 AM
sp00led's Avatar
Default Re: Odyssey Battery and 2.2L
I'm using a PC925. I mounted it in the trunk when I installed the tony1 catch can in the factory battery tray. I bought a tray that was made specificly for the PC925 but there are other options out there.
Old Feb 4, 2009 | 10:16 AM
jdmeurorlude's Avatar
^^^^^^ do you have problems with start up? or do you even daily the car? ive heard they take some extra attention and charging every few days.
Old Feb 4, 2009 | 12:27 PM
HiProfile's Avatar
Any small battery that you only occationally use, or don't drive more than 30 miles per 'startup', will require maintanence. Moreso if you idle it more for warmup. My mom drives her car 2 miles to work, and needs a charge every month.
Old Feb 4, 2009 | 12:42 PM
njn63's Avatar
Not a 2.2L, but I had a PC625 on my old CRX with a 10.6:1 D16. Still works fine a year later and has never needed a charge (my brother owns the car now). He drives about 45 miles each way to work though so it never sees short runs.
Old Feb 7, 2009 | 11:04 PM
slowsiEG's Avatar
I worked at a stereo shop where we sold these batteries for our years and during that time boosted an h22 in an EG the odyssey battery did well through about the first winter being in the engine bay. If you live in an area of extreme cold its not good for that application. if you're able to locate it to the rear of the car it would help a lot but they don't do that well with extreme temperature changes that you can see in an engine bay, this came directly from an odyssey rep not sure of his name its been a couple of years
Old Feb 7, 2009 | 11:15 PM
streetracer6rpt's Avatar
ive got an ATV battery for my H...
Old Feb 8, 2009 | 10:20 AM
94VTEC2TONE's Avatar
maybe u have a charging system problem. its a drycell battery i think, havent looked tbh. all you need is for it to turn the engine over and be capable of takin a charge of 12.7v. dont see why the battery drains for any reason
Old Feb 8, 2009 | 12:22 PM
yeah i think ill stick with my optima red top. its still a street car so screw it
Old Feb 8, 2009 | 12:38 PM
HiProfile's Avatar
Its a V6 Ford Ranger, and charging a 500+ amp battery takes more than the 2-3 minutes it takes for her to get to work. In other words, starting takes more energy out than gets put back in. Lead-acid batteries historicly do not like tons of short trips.
wsandlin
Dec 11, 2013 05:43 PM
NOFX
21
Jun 30, 2011 02:58 PM
h22mark
Aug 24, 2004 03:14 PM
tC_Dragon
Feb 23, 2003 02:36 AM
