OBX Top mount? Anyone ever run this or try it?
Saw this OBX Top mount for B-series. I'm looking for either top mount or ram horn. Is this some junk stuff welded together? Or has someone actually used this manifold before. For the price Is it actually worth it? Just want some input if i should get it or would it crack later....
http://cgi.ebay.com/ebaymotors/90-01...5809QQtcZphoto http://www.racingpartsdepot.com/pictures/10996-2.jpg http://www.racingpartsdepot.com/pictures/10996-6.jpg http://www.racingpartsdepot.com/pictures/10996.jpg |
Re: OBX Top mount? Anyone ever run this or try it?
I'd try it for $350, just add some supports.
its worth a try
Yeah, i thought about that. I wonder if anyone has ever ran this with no problems
Looks decent. Probably super thin tho. I thought MY ebay mani was pretty stout, til I compared it to My RLD ram horn I got. The Quality of the Welds/metal/collector is a NIGHT and DAY difference.
theres a guy that has one here, if he turned his little t3 t04e where the compressor faces the driver side headlight, HE CANT, when he faced it towards the radiator, HE CUT OFF HALF THE RADIATOR SUPPORT LITERALLY TO MAKE IT FIT!!
DONT BUY IT LOL!!! |
I have seen ramhorn, DP, and dumptubes all TOP notch stuff go for 400 on here used. Do that man
ok thanks for feed back guys!
If you wanna go low cost.. I've had good luck with the Blox cast manifolds. I made 350 on a stock GSR on pump with one and a T3/T4, and his buddy with a fully built motor same manifold and turbo combination laid down about 430HP @ 9K before it ran outta breathing room.. They are not bad, and you can get em for under $400 if you look around. Not good if your going for high power, but for a stock motor setup they are a really good deal and spool quick.
Originally Posted by SPOOLINmatt
(Post 37445599)
theres a guy that has one here, if he turned his little t3 t04e where the compressor faces the rad support, HE CANT, when he faces it towards the radiator, HE CUT OFF HALF THE RADIATOR SUPPORT LITERALLY TO MAKE IT FIT!!
DONT BUY IT LOL!!! Anyhow i have a friend who is running one on a B20vtec using a .63 a/r t4 flanged GT35r and it fits fine, i cant imagine a 40r going on there though... |
Originally Posted by blinx9900
(Post 37452362)
there is some confusion here for sure, that manifold only comes with a T4 flange so i fail to see how a t3/t04e would fit on it in ANY configuration.
Originally Posted by Tony the Tiger
(Post 37454466)
Best post of the day..lol
(Post 37452362)
Anyhow i have a friend who is running one on a B20vtec using a .63 a/r t4 flanged GT35r and it fits fine, i cant imagine a 40r going on there though... here is one...you CANT put the turbo on the other way or you would just have to chop a different section out. OBX TOP MOUNT. http://i99.photobucket.com/albums/l3...20816311-1.jpg |
Holy Sh-t!!
Wow.. HELLA ghetto. This manifold is a disaster waiting to happen..
(Post 37455775)
well my ****ing bad i didnt pay enough attention to the garbage to realize what size flange was on it. It is that manifold.
Beteer pic of the manifold on a car pls
I was thinking buying OBX manifold but when my 3rd OBX turbo went out, I said I'll pay more but I'm not buying it...
So I found top mount from eBay for $450 shipped with t3 flange 38mm Wastegate flange and it fits perfect. You just have to wait a little and look more, there is good used top mounts up there. No more OBX parts for me..! I know there is some used top mount for cheep at www.homemadeturbo.com |
my buddy ran one for a while.fitment was not an issue at all, nothing like that pic. This was in a delsol it lasted for a while but eventuallly it cracked and broke.
Photo Photo Photo Photo Photo Photo Photo
Originally Posted by vadimkag
(Post 37458554)
So I found top mount from eBay for $450 shipped with t3 flange 38mm Wastegate flange and it fits perfect. You just have to wait a little and look more, there is good used top mounts up there. No more OBX parts for me..! It may not say OBX on the box, but I can almost guarantee you the same chinese knock off company made it. |
holy turbo batman!
Originally Posted by 93CX
(Post 37459601)
maybe theres a huge inconsistency in their "JIG"
ROFL!! :P just buy a BLOX manifold, much less heart ache. |
Not to mention the intercooler is about 2" off the ground on that green car. The drivers side headlight is held on with 1 of the top bolts b/c the rest is cut and bounces horribly. The radiator support is also very easy to move around as well, as you would imagine. The funny part is, he thinks it will pass tech @ Atlanta Dragway for the IFO event!
