OBD2b to OBD1 - what needed?
Old Feb 23, 2005 | 02:54 AM
mrx's Avatar
mrx
Default OBD2b to OBD1 - what needed?
Hallo,
i have a OBD2b P73 ECU. what do i need to run a obd1 p30 ecu i.e. on a obd2b integra type r b18 engine.
i know i need the adapter harness and the obd1 ecu... and if i swap from obd0 to obd1 i need the o2 sensor and the distributor... but i'am not sure how it is with obd2 and obd1... maybe someone can help.
Thanks
Malte.
Old Feb 23, 2005 | 05:31 AM
project dc2's Avatar
Default Re: OBD2b to OBD1 - what needed? (mrx)
all you need is the adapter harness and ecu.
Old Feb 23, 2005 | 06:02 AM
platinum00's Avatar
Default Re: OBD2b to OBD1 - what needed? (project dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote">all you need is the adapter harness and ecu. </TD></TR></TABLE>
that's correct.
platinum
Old Feb 23, 2005 | 06:17 AM
DaX's Avatar
DaX
Loved
Community Favorite
Boomslang harness...$74 shipped!
Old Feb 23, 2005 | 06:19 AM
mrx's Avatar
mrx
Default Re: (DaX)
Thank you guys... thats what i want to hear...
Old Feb 23, 2005 | 06:22 AM
Blown90hatcH's Avatar
Default Re: (DaX)
As others have said, you need the OBD1 ecu and the conversion harness. Check here for the cheapest prices anywhere on the OBD conversion harnesses. No middle man. No internet pinout copiers.
https://honda-tech.com/zerothread?id=997093
Jason
Old Feb 23, 2005 | 06:38 AM
DragSource's Avatar
You will also need OBD1 Injector Clips - You will be running Peak and Hold injectors now instead of saturated.
Old Feb 23, 2005 | 06:40 AM
platinum00's Avatar
Default Re: (DragSource)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DragSource &raquo;</TD></TR><TR><TD CLASS="quote">You will also need OBD1 Injector Clips - You will be running Peak and Hold injectors now instead of saturated.</TD></TR></TABLE>
i run saturated with my ODBI p28
platinum
Old Feb 23, 2005 | 06:47 AM
DaX's Avatar
DaX
Loved
Community Favorite
What? I'm running P&H on my stock clips...no sweat.
Old Feb 23, 2005 | 06:55 AM
OBD1 injectors are still Saturated. And he can keep the OBD2 injectors as well. If he wanted to go to Peak and Hold..OBD0 injectors, then he would need to install the resistor box.
Old Feb 23, 2005 | 07:09 AM
Evanmb44's Avatar
plus you can ditch your secondary o2 sensor once you convert to obd1
Old Feb 23, 2005 | 08:30 AM
DragSource's Avatar
Default Re: (Evanmb44)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">
OBD1 injectors are still Saturated. And he can keep the OBD2 injectors as well. If he wanted to go to Peak and Hold..OBD0 injectors, then he would need to install the resistor box.</TD></TR></TABLE>
You are correct - sorry for the mis info. . . I was thinking he was going to be running DSM injectors for some reason. . .I'm retarded.
Old Feb 23, 2005 | 09:38 AM
SOHC_MShue's Avatar
Default Re: (Blown90hatcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">As others have said, you need the OBD1 ecu and the conversion harness. Check here for the cheapest prices anywhere on the OBD conversion harnesses. No middle man. No internet pinout copiers.
Jason</TD></TR></TABLE>
damn you seem to have a good selection
Old Feb 23, 2005 | 11:47 AM
Default Re: (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">
damn you seem to have a good selection </TD></TR></TABLE>
I have the biggest selection PERIOD! I have been doing this for a while man. If someone is doing something custom and needs it, I will make it no problems.
Old Feb 23, 2005 | 12:11 PM
SOHC_MShue's Avatar
sounds good
Old Feb 24, 2005 | 04:14 AM
hondaapi's Avatar
I have a p28 laying around. Does it mean I can run the p28 on the b18c6 with the correct harness?
Old Feb 24, 2005 | 07:58 AM
projectxspeed's Avatar
Default Re: (hondaapi)
Yes you can, but you need to have the p28 chipped first to properly run your b18c
Old Feb 25, 2005 | 12:36 AM
hondaapi's Avatar
Default Re: (projectxspeed)
of course. it is clear that it has to be chipped at first. thanks for the infos.
00garrettsi
Jul 19, 2007 05:10 PM
big-cat
26
Oct 19, 2006 11:14 AM
youre_scum
Jun 27, 2006 12:34 AM
yeegsr
15
Apr 3, 2006 06:36 PM
C_I_V_I_C
Nov 5, 2003 05:26 PM
