OBD 2 Test Pipe which one
Old Dec 12, 2002 | 11:36 AM
TURBOED-TEG's Avatar
Default OBD 2 Test Pipe which one
Anybody have an OBD 2 LS with a Drag kit on it? If so and you have gotten rid of the stock cat which test pipe or hi-flo cat did you use. How much of an increase did you get?
I think that my cat is holding me back - before I turboed my car I put a Apexi N1 cat back on it and the exhaust didn't get much louder then stock, my brother put a HKS catback on his SOHC Civic and it roars!! WTF
Old Dec 12, 2002 | 03:31 PM
Default Re: OBD 2 Test Pipe which one (TURBOED-TEG)
ttt
Old Dec 13, 2002 | 04:05 AM
Come on somebody has to have some sort of advice
Old Dec 13, 2002 | 04:27 AM
LOwrestling2001's Avatar
hi flow cat
Old Dec 13, 2002 | 04:29 AM
M.A.R.C.'s Avatar
a stock cat will always hold u back. i recommend a testpipe from http://www.testpipe.com (i just got one and put it in last nite, pretty decent piece). Make sure u specify ur model year when ordering. About the sound... it's pretty much all in the muffler, and remember... loudness isn't always a good measure of power
Old Dec 13, 2002 | 05:01 AM
Default Re: OBD 2 Test Pipe which one (CivicRyda2k)
Well, an Apexi N1 isn't exactly a quiet exhaust...could it be possible that my cat is clogged, I get a little compressor surge too! I don't want to throw codes do they have a test pipe that will work with OBD2 - Typically I have found that and exhaust will help to open up the engine, this didn't help open up anything, sounds the same even with turbo as it did stock basically - not exactly I mean it is a little louder but not much, not much at all - I was very surprised as to how quiet it was!
Old Dec 13, 2002 | 07:15 AM
swrdply400mrelay's Avatar
Added back pressure of the turbo quiets the exhaust. Also, being OBDII you have a few options:
1. Convert from OBDII to OBDI and get a test pipe.
2. Buy an ECG O2 simulator from importparts.com and get a test pipe.
3. Get a high flow cat.
Old Dec 13, 2002 | 07:50 AM
Default Re: OBD 2 Test Pipe which one (swrdply400mrelay)
Sure the backpressue deal with turbo I understand that, but before I boosted the car I had the exhaust and it was still very very quiet! What are the symptoms of a clogged cat?
Old Dec 14, 2002 | 09:04 AM
ttt
Old Dec 14, 2002 | 09:17 AM
IMALLSLO's Avatar
Every obd2 car ive ever put a test-pipe on throws a cel. The primary 02 and secodary 02 have to have a slightly different reading. Using a straight pipe doesnt allow for that. Best bet is to put the ecg o2 sim. and your set.
Old Dec 14, 2002 | 12:46 PM
Default Re: OBD 2 Test Pipe which one (proclassracer)
Ok then if I put the ECG o2 simulator on it would I need to worry about buying a "test pipe" with a bung in it, or could I just have the cat removed and then run straight pipe from the turbo back? (no bung)
Old Dec 14, 2002 | 02:54 PM
zip's Avatar
zip
Yes, with the O2SIM you will no longer need a bung on the test-pipe. The second O2 sensor can be totally removed.
jdmboy96
Mid-Atlantic (Sales)
Feb 1, 2009 06:11 AM
fin781
21
Feb 18, 2007 09:35 AM
Fat Chick Magnet
Aug 4, 2006 04:33 PM
DpQInteg
May 13, 2006 07:40 AM
Nsane
Aug 8, 2005 10:09 PM
