OBD-0 to OBD-1 conversion help!!!!!!!!
Old Nov 30, 2006 | 10:33 AM
0bd1_Kanobe's Avatar
Default OBD-0 to OBD-1 conversion help!!!!!!!!
Just finished up doing the wiring on my 89DX. Did everything the instructions say's to do but seem's like the car has a short somewhere? Car ran fine before I did this stuff. Now it does not even cranck on it's own? Will Dizzy wiring cause the car not to start? Also Im still running OBD-0 injectors and resistor box. Any help will be apreciated!!!!!!!!
Old Nov 30, 2006 | 10:34 AM
bump
Old Nov 30, 2006 | 11:10 AM
xenocron's Avatar
Default Re: OBD-0 to OBD-1 conversion help!!!!!!!! (0bd1_Kanobe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0bd1_Kanobe &raquo;</TD></TR><TR><TD CLASS="quote">Now it does not even cranck on it's own? Will Dizzy wiring cause the car not to start? </TD></TR></TABLE>
Incorrect Dizzy wiring will cause the car to no start, but it will not cause it to not crank...
There is one wire going from the ignition to the starter that cause it to engage, as long as the starter is getting 12 v on that wire (which would have nothing to do with your OBD0 to OBD1 conversion) you should be good...or maybe your starter is fried now
Old Nov 30, 2006 | 11:21 AM
When I cranck the car the cluster lights go dim so im thinking that there is a short somewhere but i cant figure it out. It was not doing this before the conversion!!!!!!!
Old Nov 30, 2006 | 11:46 AM
TTT
Old Nov 30, 2006 | 12:04 PM
coneheadsracing's Avatar
Default Re: (0bd1_Kanobe)
Actually i've had my distributor wiring cause my car to not start. There is some kind of shielding in there i think, and i spliced all the wires, and then taped them all back up, like they were from the factory. Anyways, it must have caused a short, cuase the car woudn't crank or anything. I just untaped them and its been fine ever since, not my daily driver so never cared. I've also had problems with my starter wire, not having the cover on the bolt where the cable connects, causing a short there.
Old Nov 30, 2006 | 03:47 PM
On the Dizzy wiring on the engine harness I kinda did cut it all the way down to where you can see the two wire's......
Old Nov 30, 2006 | 03:49 PM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0bd1_Kanobe &raquo;</TD></TR><TR><TD CLASS="quote">When I cranck the car the cluster lights go dim so im thinking that there is a short somewhere but i cant figure it out. It was not doing this before the conversion!!!!!!!</TD></TR></TABLE>
Recheck all your connections
Old Nov 30, 2006 | 03:54 PM
Can anybody post a Diagram on wich colors go to what color's from the Dizzy to the harness
Old Nov 30, 2006 | 03:56 PM
Only thing I wired up was Dizzy, Vtec, and knock other than that everything is the same!!!!!
Old Nov 30, 2006 | 05:17 PM
turboekcivic's Avatar
I it don't crank then check ur main ground to the tranny. Unless u didn't even touch the ground then its probably the signal wire on the starter color black w/ yellow stripe. Check that first. Then make sure ur fuses are cool. Even if it was the distributor the car would still crank but won't start.
Old Nov 30, 2006 | 05:18 PM
also make sure ur battery is full.
Old Nov 30, 2006 | 05:28 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0bd1_Kanobe &raquo;</TD></TR><TR><TD CLASS="quote">Can anybody post a Diagram on wich colors go to what color's from the Dizzy to the harness </TD></TR></TABLE>
Yeah let me get on that for you, one second.
Old Nov 30, 2006 | 05:29 PM
OBD0 OBD1
orange orange
white white
orange/blue orange/blue
white/blue white/blue
blue/green blue/green
blue/yellow blue/yellow
large white yellow/green &lt;only color that is different
black/yellow black/yellow
blue blue
Old Nov 30, 2006 | 05:36 PM
Blown90hatcH's Avatar
Default Re: OBD-0 to OBD-1 conversion help!!!!!!!! (90blackcrx)
Not all pre-obd (OBD0) to OBD1 conversion harnesses are wired such that you can just match colors like that. Post who you bought the harness from and also post in the EF forum. There are millions of threads like this in there.
Old Nov 30, 2006 | 05:38 PM
Default Re: OBD-0 to OBD-1 conversion help!!!!!!!! (Blown90hatcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">Not all pre-obd (OBD0) to OBD1 conversion harnesses are wired such that you can just match colors like that. Post who you bought the harness from and also post in the EF forum. There are millions of threads like this in there.</TD></TR></TABLE>
Yep, but most are, well all the ones I have used are. And the dizzy king wire colors are totally different, fyi
Old Nov 30, 2006 | 05:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">
Yep, but most are, well all the ones I have used are. And the dizzy king wire colors are totally different, fyi</TD></TR></TABLE>
Lol...Everyone and their sister makes one now. I hope that fyi isn't for me..lol
Old Nov 30, 2006 | 05:44 PM
Lol...Everyone and their sister makes one now. I hope that fyi isn't for me..lol</TD></TR></TABLE>
It was directly aimed at you... just kidding.
Old Nov 30, 2006 | 06:07 PM
I bought conversion harness on Ebay, its a Avid piece and I think that I wired everything right. Also did this by accident, I connected the battery ground to the batterypositive but never hooked the power up because I caught my mistake. Will check the grounds
Old Nov 30, 2006 | 06:59 PM
Got it to cranck I forgot that I had disconected the valve cover ground. I still dont think im getting spark
Old Nov 30, 2006 | 08:46 PM
Wiring done but im not getting spark, the only thing that I think it is that i might have crossed the Blue green/Blue yellow wire's backwards. Will this cause the dizzy not to spark? I tried switching them over but still wont spark!!!!!!!
Old Dec 5, 2006 | 03:09 PM
Pull out a plug, put it into a plug wire, and ground it on the chassis. Have a friend crank it for a second and see if you got any spark. Also, check to make sure you put your plug wires back on the dizzy properly too.
Old Dec 6, 2006 | 05:05 PM
Thanks for all the input!!!!!!!!!
Old Jan 3, 2007 | 05:29 PM
95_red_dc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">OBD0 OBD1
orange orange
white white
blue blue</TD></TR></TABLE>
I am double checking my wireing for my conversion and I dont know which one is the fat white wire, which white wire goes off by it self?
Old Jan 3, 2007 | 05:47 PM
95_red_dc's Avatar
Default Re: OBD-0 to OBD-1 conversion help!!!!!!!! (ls_swaped_crx)
I am middle of checking my wires and I searched Found this forum it helped out but which white wire is the fat one?
