O2 sensor; before or after the turbo?
Old Jan 29, 2004 | 01:35 PM
warchild69's Avatar
Default O2 sensor; before or after the turbo?
hey i have got most of my stuff together for my turbo swap.... i see most cars have the o2 sensor after the turbo but does this matter at all? see im using a HF manifold and a adapter to the turbo.... the down pipe will have to be custom made do it would be good to know if i need to plug the hole on top or what... maybe i will run my exh. temp sensor from there? thanx
Old Jan 29, 2004 | 01:36 PM
redboost10's Avatar
Default Re: O2 sensor; before or after the turbo? (warchild69)
are you talking about egt? and o2
Old Jan 29, 2004 | 01:37 PM
warchild69's Avatar
Default Re: O2 sensor; before or after the turbo? (tgh99si)
well i already got the egt and i need to know if i should put my o2 sensor back in the exhaust manifold or after the turbo......
Old Jan 29, 2004 | 01:38 PM
redboost10's Avatar
put egt in cylinder 3 on the manifold and put the o2 on the downpipe right after the turbo
Old Jan 29, 2004 | 01:41 PM
Bailhatch's Avatar
I ran the stock O2 in the top of my old HF manifold. worked fine. I would put the EGT there though and the O2 in the DP.
Old Jan 29, 2004 | 01:52 PM
warchild69's Avatar
Default Re: O2 sensor; before or after the turbo? (Bailhatch)
thanx guys i just wanted to get a few others advice on it before i screw it up!
Old Jan 29, 2004 | 01:53 PM
redboost10's Avatar
no problem, another thing put the egt about 1-2 inches away from the head, and the o2 sensor im not sure but i have seen them about 3 inches away from the turbine outlet on the dp
Old Jan 30, 2004 | 05:07 AM
warchild69's Avatar
thanx guys i will start the project about mid feb. and will take pix
spiceisler
Mar 23, 2004 03:32 AM
EU BATT
Nov 21, 2002 02:48 PM
Ri5e
Mar 27, 2002 08:09 PM
