noob to turbo please help
Old Jul 8, 2005 | 10:43 AM
sloweredcivic's Avatar
Default noob to turbo please help
i have searched first off
i have a b16a in my 90 hatch completely stock internally for now i will be putting a 75 shot to it next week.
but iwant a turbo bad,
my questions
i want a turbo kit or to piece one thogether that will work great with a stock motor 11lbs. max but i also want to be able to grow with the kit like somthing effeciaent to 20 lbs. later on.
i was looking at peak boost but then i found the top mount turbo setups.
does anyone have dyno charts to show the difference between ram horn style and top mount style manifolds. i just don't know wich i want and if one is better than the other. thanks
Old Jul 8, 2005 | 11:56 AM
EGP's Avatar
EGP
Default Re: noob to turbo please help (sloweredcivic)
Just read, read, read. Your not going to get all the answer to a hugely complicated project like turbo charging in one thread. Read your *** off.
Old Jul 8, 2005 | 12:40 PM
adseguy's Avatar
Default Re: noob to turbo please help (EGP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGP &raquo;</TD></TR><TR><TD CLASS="quote">Just read, read, read. Your not going to get all the answer to a hugely complicated project like turbo charging in one thread. Read your *** off.</TD></TR></TABLE>
... you just haven't serached enough
If you want a lot of power later on then you'll need to build your own kit or go full-race and spend the money. Find out what size injectors and IC and turbo and Downpipe and etc etc etc....you can find all this with other setups that made nice power....try searching Boosted-hybrid's "big" cars or MASE's "big" cars...you'll see there setups and you'll get an idea
Old Jul 10, 2005 | 03:41 AM
95GSRT's Avatar
you should base your turbo kit on how much power you want to make, not how many pounds of boost you will run. Like the other guys said do all your research before.
Old Jul 10, 2005 | 10:15 AM
i would like 300-320 on stock b16a bottome end till i can sleeve an ls bottom end and put rods and pistons in it then maybew 350-375 how much harder is it to make 400
Old Jul 10, 2005 | 11:41 AM
2000psi's Avatar
From: We Cant Stop Here This Is Bat Country, So CaL, USDM
Default Re: (sloweredcivic)
dude slow down.....
You should just build your own basic kit for now. You should aim for ~200whp maximum for your first setup. 200 whp is gonna feel really fast if you've never had a turbo especially in a hatch. 300whp is gonna get you wrapped around a tree, I don't think you realize how little traction you're going to have at 300+whp. I don't think anyone here has started out with over 300 hp for their first turbo setup.
good luck and read read read.
Old Jul 10, 2005 | 11:25 PM
i know what you mean my freinds hatch dynoed 293 after 20 or so pulls and it was like 95 degrees out the day so i know i shouldn't expect traction till 4th gear i just meant those are my expectations on my stock motor i was plaining on a dual stage boost controller 5 or 6 daliy driving and 11 at the strip
Old Jul 10, 2005 | 11:42 PM
Cloner's Avatar
Yeah 335hp feels crazy on the street.If your not use to the force it feels like you cant see.Its like a drug and you just want more cause you get immune to it real fast.When you launch too hard it feels like the ground is ice.I dont know which one I like better torque or horsepower they both feel good.
Old Jul 11, 2005 | 02:03 AM
lucidvtec's Avatar
i suggest buildin the motor first..then u will have less problems
SunDropCRX
Oct 7, 2008 08:14 AM
only1crx
Apr 15, 2005 08:52 AM
civic909
Sep 22, 2004 12:29 PM
Filliam H. Muffman
Oct 3, 2003 02:59 AM
veilsides2000
Honda S2000
66
Jul 15, 2003 07:52 AM
