Noob Question: How To Turn Up BOOST
Old Jan 1, 2007 | 10:09 PM
Tuner85's Avatar
Default Noob Question: How To Turn Up BOOST
I know this is a noob question but how exactly do you turn up the boost on a turbo kit? Is it the wastegate because I see how some say they have a 6psi or 8psi spring in them or something. Also how do boost controllers work and is that all i need to turn up the boost? How does something you plug in make something build up more pressure?
Any help would be much apprecaited. Thanks - T85
P.S. - If anyone has a COMPLETE Turbo Kit for a D-Series engine then I would be interested in purchasing it if its going for less than $1,000.
Old Jan 1, 2007 | 11:24 PM
Gold DA9's Avatar
Default Re: Noob Question: How To Turn Up BOOST (Racer85)
Pm'ed
Old Jan 1, 2007 | 11:37 PM
igo4bmx's Avatar
1- internal gate - tighten actuator arm, or boost controller
2- external gate - boost controller
Old Jan 2, 2007 | 04:10 AM
MiraiZ's Avatar
Default Re: (igo4bmx)
drill a hole in the wastegate...ehehe
Old Jan 2, 2007 | 07:20 AM
Schister66's Avatar
Man U FTW
i'm just going to toss this out there....you know you need to be retune for the higher pressure once you turn up the boost...right?? Just hoping to avoid and embarassing event
Old Jan 2, 2007 | 07:31 AM
ryan89crx's Avatar
if you dont know how to turn up the boost, you probably shouldnt do it even if you find out how...
Old Jan 2, 2007 | 09:58 AM
EJgsr's Avatar
Default Re: (ryan89crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryan89crx &raquo;</TD></TR><TR><TD CLASS="quote">if you dont know how to turn up the boost, you probably shouldnt do it even if you find out how...</TD></TR></TABLE>
x2
Old Jan 2, 2007 | 10:02 AM
dpetro1's Avatar
2- external gate - boost controller or heavier spring
x3
Old Jan 2, 2007 | 12:30 PM
Bseriescivic5's Avatar
pull off the vac line from the wastegate and go have fun.
Old Jan 2, 2007 | 07:38 PM
Gold DA9's Avatar
Default Re: (Bseriescivic5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bseriescivic5 &raquo;</TD></TR><TR><TD CLASS="quote">pull off the vac line from the wastegate and go have fun.</TD></TR></TABLE>
HAHAHAHA, did that before on a internally gated IHI RHB5. It helped me beat my friends B16 CRX with I/H/E that dynoed 143whp. I was boosting 12psi and it was holding but my clutch wasn't. Surprisingly only got a cell a few times, but then I put the vac line back on. Motor being replaced soon.
Old Jan 3, 2007 | 12:21 PM
Tuner85's Avatar
If you don't have any information pertaining to the topic and are just wanting to add another post to your score than I advise you to go somewhere else because everyone has had a noob question at least once. Who was born knowing everything there is to know about turbos or anything for that matter,NOONE and we all know not you because if so then you wouldn't have posted sumthing not pertaining to the topic at all, you know the crap we all hate when someone chimes in when they should be the LAST person talking.
Old Jan 3, 2007 | 01:17 PM
Schister66's Avatar
Man U FTW
easy killer.....
Old Jan 3, 2007 | 03:56 PM
TurbodTegSfaria's Avatar
Default Re: (Schister66)
someones getting a lil angry
Old Jan 3, 2007 | 04:56 PM
ryan89crx's Avatar
Default Re: (Tuner85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tuner85 &raquo;</TD></TR><TR><TD CLASS="quote">If you don't have any information pertaining to the topic and are just wanting to add another post to your score than I advise you to go somewhere else because everyone has had a noob question at least once. Who was born knowing everything there is to know about turbos or anything for that matter,NOONE and we all know not you because if so then you wouldn't have posted sumthing not pertaining to the topic at all, you know the crap we all hate when someone chimes in when they should be the LAST person talking. </TD></TR></TABLE>most noobs use the search feature first
top right, in red letters
sc4dr's Avatar
I believe you mean NONE. shrugs sholders
Old Jan 3, 2007 | 05:15 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (sc4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sc4dr &raquo;</TD></TR><TR><TD CLASS="quote">I believe you mean NONE. shrugs sholders</TD></TR></TABLE>
x2
Old Jan 3, 2007 | 07:07 PM
ImportHatch's Avatar
Default Re: (wantboost)
I usually never say this but this is ridiculous..... You seriously think this hasnt been covered a ton of times or you couldn't just search on google? You could have found it faster than you could have made this post. Just use a little common sense.
Yager-
Old Jan 3, 2007 | 08:48 PM
wenlyone's Avatar
Default Re: (Gold DA9)
lol. must have been good fun.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gold DA9 &raquo;</TD></TR><TR><TD CLASS="quote">
HAHAHAHA, did that before on a internally gated IHI RHB5. It helped me beat my friends B16 CRX with I/H/E that dynoed 143whp. I was boosting 12psi and it was holding but my clutch wasn't. Surprisingly only got a cell a few times, but then I put the vac line back on. Motor being replaced soon.</TD></TR></TABLE>
SloB16crxMike
Aug 15, 2006 10:31 AM
Luchini
Nov 6, 2005 06:28 PM
mrod006
Jan 31, 2003 06:30 AM
1tyme
Nov 27, 2002 05:32 PM
Integra187
Sep 21, 2001 07:13 PM
