nonvtec turbo setup good or bad?
Old Apr 21, 2005 | 12:05 PM
erebunicrx's Avatar
Default nonvtec turbo setup good or bad?
right now i have a b20 block that came with a p8r head. i was going allmotor and decided to turbo my motor.
after posting and doing a little research i found out that a b20 sleeves are not worth boosting. so i was going to sell everything i have for the b20 and go with a sleeved ls vtec turbo. the problem is i can not sell my head for ****. it is the p8r head but i have crower springs and retainers and just got a 3angle valve job.
my goal is somewhere in the high 400's if possible.
my question is should i stick with the p8r head or take a huge loss and go with a vtec head?
Old Apr 21, 2005 | 12:46 PM
nonvtecD's Avatar
that head will be fine just turn up the boost to make more power
Old Apr 21, 2005 | 03:26 PM
erebunicrx's Avatar
anyone else using a p8r head?
Old Apr 21, 2005 | 03:51 PM
s2kdre's Avatar
Default Re: (erebunicrx)
you can do 400 whp on a stock ls or b20 head all day long.
s2kdre's Avatar
Default Re: (jdmhonda)
everybody just goes vtec because you'll get bigger power faster.
Old Apr 21, 2005 | 04:14 PM
DragSource's Avatar
You could probably get a P&P on that head and some cams for near the price of the VTEC heads.
Old Apr 21, 2005 | 04:45 PM
s2kdre's Avatar
Default Re: (DragSource)
vtec heads go for about 500 bucks, crower cams for an ls are 420 plus springs 350, ita a little more but i rather go with an ls and make 400 which i am so i just wanna stay with an ls.
Old Apr 21, 2005 | 04:57 PM
DragSource's Avatar
Yes, VTEC heads can be obtained for 500-600 dollars used.
You only pay $420 for Crower cams if you buy directly from Crower. Besides, the crower 402 and 403 cams are only $355 currently.
Old Apr 21, 2005 | 05:19 PM
erebunicrx's Avatar
what kinda power gains do you see from the cams? does it depnd on how much boost? i already have the crower springs and retainers in it and the intake valves are 33mm instead of the normal 31. so i think im going to keep the head. thanks guys
Jap.Doe
Jul 13, 2012 10:29 AM
gearhead818
Mar 21, 2010 07:48 PM
volcom_7_1
Jun 20, 2009 04:08 PM
shotime
Aug 30, 2007 09:53 PM
fullracecrxsi87
Oct 29, 2005 07:18 AM
