no room for filter on hatch
Old Oct 31, 2004 | 07:56 AM
Gsr_Hybrid_theory's Avatar
Default no room for filter on hatch
in my hatch, with a gsr motor turbo... w. no A/C
i got no room to throw my filter... cept run a custom tube near the shock tower and stock airbox resonator would sit... any ideas?
and considering i have a fluidyne rad & slimline fan, the overflow bottle sits... well, where ever i choose to put it for that moment
Old Oct 31, 2004 | 08:05 AM
Maveric's Avatar
Default Re: no room for filter on hatch (Gsr_Hybrid_theory)
just put a screen(like a screen door ) over the inlet
Old Oct 31, 2004 | 08:38 AM
alpha's Avatar
You have enough room. Trust me. You just need to find the right filter.
http://www.knpowersports.com/u...l.htm
Old Oct 31, 2004 | 09:01 AM
J337_UNIT's Avatar
Default Re: no room for filter on hatch (0x64)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 &raquo;</TD></TR><TR><TD CLASS="quote">You have enough room. Trust me. You just need to find the right filter.
http://www.knpowersports.com/u...l.htm</TD></TR></TABLE>
looks like the hydrolic clutch line thing there is in the way of putting a filter.
Old Oct 31, 2004 | 09:10 AM
alpha's Avatar
Default Re: no room for filter on hatch (J337_UNIT)
Yes but he should be able to get an angled filter in there.
Old Nov 3, 2004 | 05:04 AM
i got the u shaped pipe as well as the little "l" w. the drag stamped in it...
have no room ESP w/ the filter they decided to give me
and i cant just put a screen over the inlet due to the fan being right there..
i let it idle once, and the temp skyrocketed after like 5-10 mins to a line before the itty bitty H
Old Nov 3, 2004 | 05:35 AM
Finland's Avatar
Just do what I did. You need the cone filter of your choice, some silicone couplers, a 3" aluminum L, and a 3" aluminum U, some hose clamps, and a hack saw. The filter gets placed in the area inside the front right fender (after you remove the stock silencer)
Old Nov 3, 2004 | 06:21 AM
underpressure02's Avatar
All I did was take an old cold air intake cut it where the angle was so it angled down towards the ground and put a filter on it.
Old Nov 3, 2004 | 06:32 AM
Default Re: no room for filter on hatch (underpressure02)
hmmm nice
now how did u hook up the overflow tank? cuase well mine sucks in its location
Old Nov 3, 2004 | 06:36 AM
mine is still in the stock location. I did not move it.
Old Nov 3, 2004 | 07:11 AM
MrSmith's Avatar
I have a similar cold air setup, filter sits in the fenderwell:
Old Nov 3, 2004 | 07:22 AM
mrbsponge's Avatar
i am having a similar problem in my hatch too, my clutch hard line is getting in the way of ANYthing i try to cram in there, and i too am getting fan washout real bad. im gonna try to rig it up with something
Old Nov 3, 2004 | 07:47 AM
civperc's Avatar
Default Re: (mrbsponge)
looks like there's enough room to put something like an hks mushroom cloud right on the compressor (?)
Old Nov 3, 2004 | 08:12 AM
Turbo E's Avatar
greddy
Old Nov 3, 2004 | 08:30 AM
m R g S r's Avatar
Default Re: no room for filter on hatch (syckturboITR)
Is that steel braied line I see for vaccuum?
Old Nov 3, 2004 | 08:37 AM
Finland's Avatar
Default Re: no room for filter on hatch (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">Is that steel braied line I see for vaccuum?</TD></TR></TABLE>
I guess you edited this...if you are referring to my setup, no missing links...the car is Hondata tuned. The manifold you see is just sandwiched between the map sensor and intake...just a little piece I machined a few years ago. I use steel braid for the blow off and wastegate boost/vacuum because I don't want any failures there from regular vacuum hose.
jdmcivic2fast
Jun 22, 2011 07:32 PM
HATCHBACK GORILLA!
23
May 13, 2008 06:07 PM
wreckedmyteg
Apr 18, 2004 06:39 PM
Urban Business
30
Apr 29, 2003 10:33 AM
