no reading on dipstick???
Old Aug 15, 2007 | 05:30 AM
  #26
HT Chaplain's Avatar
Loved
Default Re: no reading on dipstick??? (josh0407)
maybe its so clean you cant see it? are you checking it the dark
Old Aug 15, 2007 | 05:33 AM
  #27
josh0407's Avatar
Hey John (alpha) Come Over And See If You Can Find The Missing Oil
Old Aug 15, 2007 | 03:22 PM
  #28
josh0407's Avatar
if i drive the car for a min and then get out and check the oil, there will be oil all over the dip stick then when i put it back in for a fresh reading the dipstick is bone dry. i put 2 more qt in today and still no reading.
Old Aug 15, 2007 | 03:28 PM
  #29
fmfkid250's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by josh0407 &raquo;</TD></TR><TR><TD CLASS="quote">if i drive the car for a min and then get out and check the oil, there will be oil all over the dip stick then when i put it back in for a fresh reading the dipstick is bone dry. i put 2 more qt in today and still no reading.</TD></TR></TABLE>
lol@!$@#%@Q#
Keep adding oil till it shows!!@@#%
btw a Qt is 32 OZ!!
Old Aug 15, 2007 | 03:48 PM
  #30
thewrai6th's Avatar
Default Re: no reading on dipstick??? (fmfkid250)
This thread is fuking hillarious. Are you thinking a quart is 1/4 of the bottle of oil?!?!?
You are seriously low on oil. Put more in, just keep putting it in until it fills up the head. Then take pics and post them
Old Aug 15, 2007 | 03:59 PM
  #31
josh0407's Avatar
Default Re: no reading on dipstick??? (thewrai6th)
NO **** THETES AN OIL tROLL in my motor. well tomorrow im gona drain the oil and see how much oil comes out
Old Aug 15, 2007 | 04:02 PM
  #32
thewrai6th's Avatar
That is a very good plan. But if you are not measuring correctly, you'll still be wrong.
Put it in an empty milk gallon, you should have more than 1 gallon, but NOT 2
Old Aug 15, 2007 | 04:04 PM
  #33
josh0407's Avatar
and theres no oil in the coolant either
Old Aug 15, 2007 | 04:06 PM
  #34
fmfkid250's Avatar
This has to be a joke....
Its really not even funny anymore...
Old Aug 15, 2007 | 04:31 PM
  #35
HarfordCTR's Avatar
Default Re: (fmfkid250)
so far he has put 6 qts in there. hahaha. WTF!
Old Aug 15, 2007 | 04:59 PM
  #36
jmm96gsr's Avatar
Default Re: (HarfordCTR)
It is impossible for you to put 6 quarts in and not have anything on the dipstick. He probably thinks the quart of oil it is actually a gallon.
Old Aug 15, 2007 | 06:06 PM
  #37
josh0407's Avatar
Default Re: (jmm96gsr)
actually i put 9 qts in since saturday. so where is the oil going? i have a small oil leak but not that bad around the pan gasket
Old Aug 15, 2007 | 06:25 PM
  #38
integra3586's Avatar
Default Re: (josh0407)
subscribed for outcome!!!!
  #39
DCxMagus's Avatar
ok so you have put 9 bottles of oil in your car?
if you put 9 bottles of oil in your car it would probably be flowing out of the dipstick tube dude.
thats over double what your engine requires.
is your driveway brown when before this problem happened it was white?
Old Aug 16, 2007 | 06:08 AM
  #40
josh0407's Avatar
Default Re: (DCxMagus)
So I Drained The Oil And There Was Practically None In The Pan. Wtf??? Its Leaking Real Bad On The Ran Where The Tranny Is. The Only Thing I Can Think Of Is That Its Draining Out While Im Driving. Is It Possible For 2 Gallons Of Oil To Drain Out While Your Driving In 5 Days?
Old Aug 16, 2007 | 06:35 AM
  #41
josh0407's Avatar
Default Re: no reading on dipstick??? (HT Chaplain)
Can I Use Rvt Sealant Instead Of An Oil Pan Gasket? Honda Doesnt Have Any Oil Pan Gaskets In Stock And I Wont Use Discount Auto Junk
Old Aug 16, 2007 | 07:42 AM
  #42
WishinItWas's Avatar
how could you not see/smell that much oil during/after driving ????????
Old Aug 16, 2007 | 07:51 AM
  #43
twkdCD595's Avatar
you sure it is the pan leaking and not the main seal.
although either way you should have noticed the unintentional release of a gallon or more of liquid petroleum hydrocarbon below your car.
Old Aug 16, 2007 | 08:48 AM
  #44
josh0407's Avatar
Default Re: no reading on dipstick??? (twkdCD595)
no its the pan i used a piece of junk discount pan gasket and when you start the car you can see it leaking out of the gasket. so now i bought a new gasket and will put it on tomorrow. the oil leaks out when i drive, not when the car is parked. only a little leaks out when it sits cuz the oil settles in the pan
Old Aug 16, 2007 | 09:21 AM
  #45
jchrm80's Avatar
maybe dont tighten the oil pan gasket bolts to hard?
shifts
13
Nov 16, 2007 11:37 AM
crazyguy
Sep 27, 2007 04:38 PM
invisible
21
Dec 27, 2006 08:27 AM
RGoose18
Nov 10, 2003 02:33 AM
sjteg
Sep 21, 2003 06:27 PM
