No power when i hit boost
Old May 21, 2006 | 03:06 PM
carbonkid's Avatar
Default No power when i hit boost
Ok i have a d16z6 with a greddy kit on it. Running a 12:1 vortech fmu, with my timing retarded 2 degrees, one degree colder spark plugs. Ok thats what i got now for the problem, i can drive the car around fine when i dont hit boost. But when i get on it then come to a stop, the check engine light is on, and when i start to go it feels like the car has no power and hesisiates alot. I shut the car off and turn it back on and its fine untill i hit boost, this ever happen to anyone here? This just started happening recently, is it a sensor? my injectors not flowing? thanks
Old May 22, 2006 | 09:14 AM
carbonkid's Avatar
Default Re: No power when i hit boost (carbonkid)
No one on honda tech can help me?
Old May 22, 2006 | 10:01 AM
ekhatchgrl's Avatar
What code is it pulling would be a good start.
Old May 22, 2006 | 10:08 AM
whitegsr786's Avatar
are you using check valves or the missing link to bleed boost off the MAP sensor. have yourself from the hassle and get your ecu chipped and tuned on some sort of ems...
Old May 22, 2006 | 10:29 AM
b16adx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekhatchgrl &raquo;</TD></TR><TR><TD CLASS="quote">What code is it pulling would be a good start.</TD></TR></TABLE>
best place to start
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whitegsr786 &raquo;</TD></TR><TR><TD CLASS="quote">are you using check valves or the missing link to bleed boost off the MAP sensor. have yourself from the hassle and get your ecu chipped and tuned on some sort of ems...</TD></TR></TABLE>
Fromt the sounds of it your probably not running check valves or a missing link....get a good ems
Old May 22, 2006 | 11:43 AM
carbonkid's Avatar
i read you dont need check valves for anything under 10psi
Old May 22, 2006 | 12:27 PM
bdavis's Avatar
Default Re: (carbonkid)
you do need them! your map sensor is seeing boost and throws a cel
Old May 22, 2006 | 12:42 PM
carbonkid's Avatar
if it throws a code then why does my car start acting up, feels like it has less power than stock and bucks?
Old May 22, 2006 | 12:48 PM
Spec R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carbonkid &raquo;</TD></TR><TR><TD CLASS="quote">if it throws a code then why does my car start acting up, feels like it has less power than stock and bucks?</TD></TR></TABLE>
its probably ignition or fuel related.
whats your spark plug gap set at? ( i know it shouldnt matter at idle...but i might as well ask)
if you're running a Z6, get your p28 chipped to run crome or uberdata. then u can ditch the FMU.
Old May 22, 2006 | 01:03 PM
carbonkid's Avatar
Ok im getting a missing link and see what happens. do i get the one mounted to the manifold or firewall?
Old May 22, 2006 | 01:30 PM
civic nation's Avatar
heck your distributor rotor
Old May 22, 2006 | 02:03 PM
b16adx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carbonkid &raquo;</TD></TR><TR><TD CLASS="quote">i read you dont need check valves for anything under 10psi</TD></TR></TABLE>
you read wrong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carbonkid &raquo;</TD></TR><TR><TD CLASS="quote">Ok im getting a missing link and see what happens. do i get the one mounted to the manifold or firewall? </TD></TR></TABLE>
where is your map sensor at?? What kind of vehicle is it in
Old May 22, 2006 | 03:10 PM
carbonkid's Avatar
Default Re: No power when i hit boost (b16adx)
im guessing my map sensor is on the top of my manifold, so i need the manifold missing link. not the fire wall one?
Old May 22, 2006 | 03:55 PM
nonvtecD's Avatar
you need real fuel management, it's free.
Old May 22, 2006 | 04:07 PM
Jay_Sensing's Avatar
Ditto, you can chip the ECU and run real management for less than what you will pay for that Missing Link. There is no reason to buy those anymore with the options available now.
Heck you can probably sell the FMU on ebay and make some spare cash for tuning as well.
Old May 23, 2006 | 04:04 PM
carbonkid's Avatar
how do i get "free" mangagment?
Old May 23, 2006 | 04:31 PM
Soccerking3000's Avatar
crome or uberdata
Old May 23, 2006 | 09:03 PM
carbonkid's Avatar
where do i get it?
Old May 23, 2006 | 10:23 PM
JDMs1eeper's Avatar
sounds like some1 needs a missing link
Old May 23, 2006 | 10:24 PM
JDMs1eeper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carbonkid &raquo;</TD></TR><TR><TD CLASS="quote">where do i get it?</TD></TR></TABLE>
ebay, get a missing link
also.. retard your timing more. how much boost u running?
Old May 24, 2006 | 12:28 AM
Default Re: (JDMs1eeper)
^^^^ no i think he is asking where can he get crome/uberdata, they are on pgmfi.org just join and you can download them.
Old May 24, 2006 | 10:25 AM
carbonkid's Avatar
im only boosting 6lbs.
Old May 24, 2006 | 01:19 PM
ok, how does that change what ems you run...
Old May 24, 2006 | 07:17 PM
marcussmith26's Avatar
I agree 100% if you are not going to tune it get a missing link, But getting your ecu chipped and then getting it tuned is not cheap. Sure go ahead download the program but there is much more to it than that.It cost me 700$ to get it chipped and tuned, But much safer this way. But on the comment you don't have to use missing link if you are under 10 psi is ture if your ecu is chipped ONLY!
Old May 25, 2006 | 06:28 AM
carbonkid's Avatar
thanks for the help guys. my girl offered to pay for my car to get tuned, but i still need a fuel pump and injectors. so im going with the missing link for now.
