no power to injectors
Old Feb 18, 2006 | 04:35 PM
brad98_teg's Avatar
Default no power to injectors
I'm doing a turbo install and am getting no power to my injectors. I replaced my odb-2 ecu with a chipped one from xenocron. On the first attempt to start it, it popped over once or twice. now it just turns over and their is absolutly no power getting to my dsm450cc injectors, but everything else seems to be working. what could be wrong?
Old Feb 18, 2006 | 05:52 PM
fmfkid250's Avatar
Default Re: no power to injectors (brad98_teg)
do u have a resister pack?
Old Feb 19, 2006 | 08:36 AM
brad98_teg's Avatar
Default Re: no power to injectors (fmfkid250)
no, but I bought the 10watt 10ohm resistors from radio shack.
Old Feb 19, 2006 | 09:43 AM
fmfkid250's Avatar
well... there should be voltage to the injectors at all times, the computer sends a ground pulse to turn them on...hope this gets u in the right directions
Old Feb 19, 2006 | 09:54 AM
Bailhatch's Avatar
check the main relay, ground on thermostat housing maybe. Do all the normal lights on the dash come on with the key on?
Old Feb 19, 2006 | 10:00 AM
Joseph Davis's Avatar
Default Re: no power to injectors (Bailhatch)
You should get power at the injectors even with bad thermo ground... although the ECU will refuse to function.
Check fuses, verify the resistor wiring, and OBD2 has a big plug (typically) under the IM that looks like it "deadends". If you pull the cap off the plug, you'll see it's really a big strip of metal pins that transfers power throughout the engine harness from a common feed... injectors, IACV, purge, etc. If that is uncapped, etc, it would cause that problem.
Old Feb 19, 2006 | 12:46 PM
fmfkid250's Avatar
Default Re: no power to injectors (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">If you pull the cap off the plug, you'll see it's really a big strip of metal pins that transfers power throughout the engine harness from a common feed... injectors, IACV, purge, etc. If that is uncapped, etc, it would cause that problem.</TD></TR></TABLE>
radio shack sucks!
Old Feb 19, 2006 | 11:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmfkid250 &raquo;</TD></TR><TR><TD CLASS="quote">
radio shack sucks!</TD></TR></TABLE>
You're going to have to explain that one to me.
Old Feb 20, 2006 | 05:32 AM
fmfkid250's Avatar
All the supplies radio shack gets are "rejects" in the eletrical industry, they buy the all the stuff that just dident quite make it and sell it for mad loot, im talken about resistors,transistors,,and so on...
Old Feb 20, 2006 | 07:53 AM
brad98_teg's Avatar
Thanks for the replys.
i possibly wired the injectors wrong because of the very little amount of color differences in the wires. could this blow out my injectors or mess anything up in my ECU that would not allow power to the injectors anymore?
Old Feb 20, 2006 | 10:16 AM
fmfkid250's Avatar
Default Re: (brad98_teg)
it could pop a fuse,
where did u put the resistors in at?
Old Feb 20, 2006 | 10:26 AM
KrispyKreme's Avatar
Default Re: (fmfkid250)
bump cuz i'm having the same problem with obd1 injectors....
Old Feb 20, 2006 | 10:49 AM
tallyturbo's Avatar
Default Re: (lshatch318)
on your dead end connector is the cap pluged in still? when i did my engine swap and turbo install i forgot to put it on the new harness and it wasnt getting power. i popped it on and it started right up
Old Feb 20, 2006 | 10:56 AM
bluemax189's Avatar
please give some proof of these reject parts. its funny how 5 years ago, everyone used the 10w 10ohm resistors from radioshack and no problems. you should back up your words.
Old Feb 20, 2006 | 01:27 PM
brad98_teg's Avatar
i will try to get pics up tonight of what all i did to help show you a lil more
Old Feb 20, 2006 | 02:24 PM
fmfkid250's Avatar
Default Re: no power to injectors (bluemax189)
I am a year away from a double E degree and my professor is a biomechanical enginer. thats where i got this information from. Thats good enuff for me to stay away from there,
i mean what is a 10ohm 10watt +or -10%
not very sig, but if one where to fail its not worth taking out a $2200 bottem end for a $0.19 resistor
that my .02 i would highly recomend getting a resistor pack off an accord on 91 teggy
Old Feb 20, 2006 | 02:35 PM
brad98_teg's Avatar
well i know i wired the resitors to the right wires on the main harness, (yellow with black stipe) i just dont know that i wired the other end of the resistor to the correct wire on the injector. funny thing is, the motor actually fired on a few cylinders, but on the next crank, absolutly nothing. im just afraid i blew the injectors??!! and now im not getting any power from the wires going to the injectors. jeez, the ***** realy hittin that fan now
Old Feb 20, 2006 | 02:38 PM
D@nnY's Avatar
did you power a ground for an injector?? you probably fried the ecu as it sends ground pulses to pen and close the injectors ....
Old Feb 20, 2006 | 06:33 PM
Everyones Hero's Avatar
Default Re: (D@nnY)
Dumb question, but is your fuel pump priming?
Pull the injectors and test them each with a 9v battery. You'll be able to hear a very light 'click' if they're working.
Also, open the ECU and see if anything looks burnt.
Old Feb 20, 2006 | 06:52 PM
fmfkid250's Avatar
if you where to short them you would have poped a fuse, in ur under hood fuse box
Old Feb 21, 2006 | 03:55 AM
brad98_teg's Avatar
We took a quick look at the fuses and none of them seemed blown. the fuel pump is opperating and we couldnt smell anything burning from the ECU
Old Feb 21, 2006 | 09:35 AM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmfkid250 &raquo;</TD></TR><TR><TD CLASS="quote">All the supplies radio shack gets are "rejects" in the eletrical industry, they buy the all the stuff that just dident quite make it and sell it for mad loot, im talken about resistors,transistors,,and so on...</TD></TR></TABLE>
Ehhh...No. This is NOT true at all.
While not all parts can be tested, batch testing is done. Any one supplier is as likely as the next to get a batch of parts that have a few bad ones in it.
Old Feb 21, 2006 | 10:11 AM
D@nnY's Avatar
did you make sure someone didnt pull the cap off thei njector power plug on the driver side by the firewall? they wont get power if you pull the capp off that gray plug...
Old Feb 22, 2006 | 03:39 PM
brad98_teg's Avatar
Default Re: (D@nnY)
well i feel like such a jackass, we checked the fuel fuse and it was blown...replaced it and it started right up. Thanks for all of the comments you guys are great.
xsianthracite
Acura TL, RL & ZDX
Dec 27, 2014 05:15 PM
Käras
16
May 10, 2011 07:23 AM
ByonSho
May 10, 2010 11:55 PM
dropNdestroyEF
Aug 2, 2007 04:35 AM
jansenrw
Nov 19, 2005 08:44 PM
