no fire....
Old Jun 26, 2009 | 09:09 PM
teg_95's Avatar
Default no fire....
the car is turbod. just got into second gear then i got into it so i could get around this car to make this tur. then the car shut of on me. so i popped the hood and noticed the the 1 cylinder plug wire was off the distributor. so i decided to check to see if i was getting spark. and im not getting any. any suggstions. and i know it need to be tuned. and about two hours before i ordered all the ECU **** to be tuned next weekend. any ideas
Old Jun 27, 2009 | 07:22 AM
teg_95's Avatar
Default Re: no fire....
nobody?
Old Jun 27, 2009 | 08:52 AM
boostedcivicsir's Avatar
Mr. Badwrench
many things can be bad. start with the basics. coil or ignitor.
Old Jun 27, 2009 | 08:13 PM
teg_95's Avatar
im doing that tomorrow. if thats not it what else?
Old Jun 27, 2009 | 08:19 PM
Joseph Davis's Avatar
The basics are fuel, fire, compression. You have no fire, verify fuel and compression before doing anything else.
Old Jun 27, 2009 | 08:36 PM
teg_95's Avatar
got fuel and everything else. just not spark. and it happened all at once. no noise nothing just shut off
Old Jun 27, 2009 | 09:07 PM
ASSuming your vehicle is the same as your screen name, check for battery voltage at the blk/yel wire on your distributor 2P connector when your key is in the on position. After that, pull the distributor cap. Rotor buttons like to fall off sometimes, the screw that retains them can fubar sensors inside the cap too.
Old Jun 27, 2009 | 09:10 PM
teg_95's Avatar
ok. ill get on that tomorrow. thanks a bunch. will update tomorrow
Old Jun 28, 2009 | 09:21 AM
teg_95's Avatar
put new dizzy, cap and rotor on today. and she fired right up. thanks for the help guys
boostedekhb
Mar 28, 2014 06:23 AM
300gtzr
Dec 16, 2008 04:02 PM
matt69vdub
Jul 23, 2007 08:35 AM
GQ Cowboy
Dec 14, 2003 09:55 PM
atli126
Oct 19, 2003 11:16 PM
