Re: No air flow to radiator..... Need help!!!!!
Originally Posted by bigodub93
(Post 50552244)
If I go this route I would have to manually turn the fan off and on. That's not the route I'm looking for.
The "Switch" in the picture is your FACTORY POWER WIRE that would normally go to the fan. |
Originally Posted by turbohatch96y7
(Post 50552250)
So you just scrolled right past my detailed explanation ??
Good luck |
Originally Posted by LightningTeg
(Post 50552260)
No...
I don't see a detailed explanation on how to wire this fan up from you in this thread. I see all the info you stated about aerodynamics and ducting.
Hence the " good luck " |
I have mine wired the same as your diagram then if that switch referents the +12v from the stock fan harness. I'm almost home I will double check. Maybe I'm just tired and missed something
(Post 50552285)
Yeah i deleted my posts
Thanks for the other info tho. It was really helpful
So I made it home and here's how it's wired up.
There aren't numbers directly next to each wire on this relay so I can't just name numbers and colors. Yellow wire is running fused straight to the battery Red wire is going to the fan Black wire from fan is going to tans. Ground Orange wire is going to stock fan plug (blk w/red)+12v Grey plug going to body ground. Hooked up this way the fan will turn on when I reaches a certain temp but doesn't turn back off until the key is turned off. Also I just moved the grey wire to one of the 2 wires on the the thermostat housing. But same results as before. Should I try the grey wire on the other 2nd wire on the housing or will that just not work. |
Broo
Ur making this way too hard Post a pic of your relay and ill tell you where to put the wires The terminal view of the relay |
Also once the coolant get to a certain temp fan comes on
Do you have hondata ? Watch the temps and make sure they drop when the fan kicks on |
1 Attachment(s)
(Post 50552769)
Broo
1 Attachment(s)
Hers a better one
I said a pic of the terminals
1 Attachment(s)
Relay
Okay put the red to the batt. With a fuse inline
The yellow to the fan positive Then the two small ones one goe to the stock fan harness {12v switched by ems} and the other goes to chassis ground Then Ground the spal fan Done |
If the fan doesnt turn off after that then you having cooling problems or things
I will got on this in about 2 hours. Thanks. So were the directions wrong?
30 and 87a are the thicker wires and 85 and 86 are the thinner wires
I didn't look at the diagram again so the colors might be reversed The way i told you to wire it will work 100 percent |
Yellow goes to batt red goes to fan. These two can be flipped doesnt matter
The grey and orange also. Switched 12v is orange which you will get from the stock fan harness The grey is going to ground |
(Post 50552887)
The grey and orange also. Switched 12v is orange which you will get from the stock fan harness The grey is going to ground Guess I have some more researching to do. |
What ems do you have? The fan doesnt always need to be running
Have a p28 with Hondata s300
You need to de-pin the and rewire the connection part of the relay. The fan signal is a negative output, so by adding the relay you have to make it a positive output.
86 and 30 need fused power 85 goes to trigger 82 goes to the spal Hope this helps |
Originally Posted by underrated
(Post 50553348)
86 and 30 need fused power 85 goes to trigger 82 goes to the spal Hope this helps 86=grey wire=needs to be 12v fused 30=yellow= 13v fused to battery 85=orange= trigger ( where is that for my car) oem fan 12v plug??? 87=red= to the spal fan |
So I might have missed it but are we wiring up NASAs newest space shuttle or a radiator fan lol?
