Nitrous ZEX Kit
Old Jun 25, 2008 | 09:21 PM
Shady420's Avatar
Default Nitrous ZEX Kit
I am currently planning on running a nitrous setup on my LS integra.
I have everything but the shot pills, I have been searching all around and relized that I only have to get ZEX pills no other. I am thinking about going with 75Shot DRY. I need a website where they actually sell the zex pills. Also I've found out I needed to use colder plugs. I have some NGK Iridums dont know if those would work. Is the seleniod necessary for this setup. If there is anything else I need to know before running this to be safe please let me kno
thanks alot
Old Jun 25, 2008 | 10:29 PM
hotrod99's Avatar
Default Re: Nitrous ZEX Kit (Shady420)
http://www.compperformancegrou...NENTS
Old Jun 26, 2008 | 01:15 PM
Shady420's Avatar
I dont understand which one of them is 75shot
Old Jun 26, 2008 | 01:16 PM
Shady420's Avatar
and how many of them Do I need
Old Jun 26, 2008 | 04:36 PM
Sr420Det's Avatar
Yes you need colder plugs, retard timing, .036 is a 75 shot I think, and you only need one on a dry shot.
Old Jun 27, 2008 | 11:18 AM
Shady420's Avatar
lol you think, I need an anwser here
Old Jun 27, 2008 | 12:13 PM
hotrod99's Avatar
Default Re: (Shady420)
you need 2 jets one for fuel and one for nitrous...im still searching on what size jets they are though
Old Jun 27, 2008 | 12:16 PM
hotrod99's Avatar
Default Re: (hotrod99)
ok found it...you need a 32 for fuel and a 38 for nitrous
Old Jun 27, 2008 | 11:28 PM
Shady420's Avatar
thanks alot dude ^^^ also. I have a ZEX Dry Kit complete kit with the smart unit and all that. I hear that its saver to run WET nitrous but it takes longer time for the installation. I want to go with WET since its safer what all will I need for WET and what exactly is the difference
Old Jun 27, 2008 | 11:38 PM
Garage 808 Hatch's Avatar
if you buy a new wet kit from ZEX, it comes with everything you need. ive installed 2 in my cars, and have the Direct Port kit now. the wet units work great. they also come with the "jets" for 55, 65, and 75 hp increases
Old Jun 27, 2008 | 11:51 PM
Shady420's Avatar
^^ I just want to get the rest of the parts and go with WET if thats possible what would the rest of the parts be if I choose to go with WET, I know that you need a selenoid what else.
Old Jun 28, 2008 | 04:46 AM
hotrod99's Avatar
someone correct me if im wrong but i think all you need is a fuel solenoid
Old Jun 28, 2008 | 07:17 AM
i dont think that would work, because the ZEX dry box has the built in rising rate regulator, thenm adding a wewt solinoid, might cause it to go lean. IMO, your best bet is to sell the dry kit, and buy a whole wet kit
Old Jun 28, 2008 | 02:03 PM
Sr420Det's Avatar
WOW do some researching first. A wet kit adds fuel and nitrous while a dry kit just adds nitrous which means youhave to have some other way of adding fuel. Either is safe as long as its tuned correctly (not neccesarly on a dyno) just get your air fuel ratios right and take a few degrees of timing. You need a fuel solenoid, a jet some way to tap into the fuel line, relay, and some way to mount the jet and adding a fuel jet if the zex box already increases fuel pressure the mix would be way to rich. So do you have any way of adding more fuel when nitrous hits? what about the a/f ratios? The jets arnt exactly right as far as power and a/fs. So sit down, smoke a blunt, and do some searching.
Modified by Sr420Det at 7:59 PM 6/28/2008
Old Jun 29, 2008 | 02:36 PM
Shady420's Avatar
lol I am just gonna stick to dry for now and get it tuned.
Old Jun 30, 2008 | 08:08 PM
ltrkstr2k's Avatar
go to Zex.com and READ. the jets you need are
38 nitrous
32 fuel
and you gotta retard the timing 4 degrees with a 75 dry shot and
the plugs you need are NGk BKR7E
have fun
RZA24
Jan 2, 2007 02:40 PM
DA9kid
Jan 1, 2007 04:50 PM
f22suzuka
Jul 27, 2003 09:59 AM
tmekjian
Jun 11, 2003 11:35 AM
ImprtTunr
Jan 17, 2002 01:24 AM
