Is Nitrous Timing retards nescessary
Old Nov 9, 2003 | 08:46 PM
ninja8oi's Avatar
Default Is Nitrous Timing retards nescessary
Is Nitrous Timing retards nescessary to run a 75 shot NX system if I already am using 2 steps colder plugs, 93 octane fuel along with NOS Off Road octane booster? I have a 95 integra LS btw
Old Nov 9, 2003 | 08:54 PM
laughinxxx's Avatar
New User
Default Re: Is Nitrous Timing retards nescessary (ninja8oi)
should be. Might want to run 100 octane unleaded to be on the safe side. Knock your timing back manually one degree and see if you detonate at all. If you don't detonate put the timing back to normal and do another pull. Check the plugs and decide from there.
Old Nov 9, 2003 | 08:57 PM
NateTEG95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninja8oi &raquo;</TD></TR><TR><TD CLASS="quote">Is Nitrous Timing retards nescessary</TD></TR></TABLE>
Necessary for what, a reliable car? Almost definatley, depends.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninja8oi &raquo;</TD></TR><TR><TD CLASS="quote">I already am using NOS Off Road octane booster</TD></TR></TABLE>
Oops. Dont factor this in, it's basically just a waste of money.
Old Nov 9, 2003 | 09:13 PM
B19CivicHB's Avatar
I agree, octane boost is a waste. Get higher octane fuel rather than wasting the cash on the "booster".
-Nick-
Old Nov 10, 2003 | 09:22 AM
ninja8oi's Avatar
Default Re: Is Nitrous Timing retards nescessary (B19CivicHB)
By denonation do you mean the spark plug's gap at the bottom looking burnt when you pull them out? How do I determine if it denonates. And if it doesn't than I can leave it at normal correct?
Old Nov 10, 2003 | 09:34 AM
laughinxxx's Avatar
New User
You'll see white specks on the plug if you are detonating. If you see any white specks quit spraying and go for higher octane fuel or retard your timing.
Old Nov 14, 2003 | 10:21 PM
cliff666's Avatar
Default Re: Is Nitrous Timing retards nescessary (laughinxxx)
so ur saying i run 100 octane and retard it say 2 degrees i should be fine someone told me i should retard mine 4 degrees i have a zex 75 shot with NKG plugs 2 steps colder for a b18b... i would like to kno more opinions
Old Nov 14, 2003 | 11:28 PM
xtal's Avatar
One thing I have always wanted to try instead of timing retard with the wet kits is to run a seperate fuel cell and pump to the nitrous lines with race gas, or even pure tolulene with some additives in it. If you're limited on nitrous, odds are a small fuel cell will do you quite nicely. You would see a substantial, safe power increase as well provided you were doing something with the extra heat.
If you're dry, you can't safely make enough power to justify a retard IMO.
Old Nov 15, 2003 | 05:58 AM
cliff666's Avatar
Default Re: Is Nitrous Timing retards nescessary (xtal)
so u are saying i theres no need to retard my timing?????
Old Nov 15, 2003 | 08:49 AM
laughinxxx's Avatar
New User
Default Re: Is Nitrous Timing retards nescessary (dragboy)
I'm saying run 100 octane with the two step colder plugs or run premium pump gas with one or two step colder plugs and two degrees of timing retard pulled.
Old Nov 21, 2003 | 12:53 AM
Mikeman191's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xtal &raquo;</TD></TR><TR><TD CLASS="quote">
Am i the only one who laughed when i read this? Just sounds funny
manuel3655
Aug 12, 2007 08:13 PM
B-motor
Nov 8, 2006 09:18 PM
soriano4521
Aug 30, 2005 12:27 PM
lsteggy
Dec 17, 2002 04:01 AM
allshownogo7
Feb 18, 2002 10:19 PM
