nitrous ques?
Old Jan 31, 2007 | 05:51 PM
jnasty's Avatar
Default nitrous ques?
i was wondering i have a 98 integra gsr putting on nitrous.for my msd digital window switch do i need a tach adaptor? also were can i tap a wire for a ignition signal for the window switch?
what mode should it be in?
thanks
Old Jan 31, 2007 | 06:10 PM
jnasty's Avatar
anyone?help?
Old Jan 31, 2007 | 07:28 PM
urbansi's Avatar
Default Re: nitrous ques? (jnasty)
You for the most part are not going to get much help on here as far as nitrous goes, more people will chime in with remarks like NAWZ and ****
Honestly i think that 90% of the people that post here dont know what the hell a window switch is anyways. Attempt to contact MSD, and do some other searching online.
Sorry i couldnt be more help.
Old Feb 1, 2007 | 08:54 AM
fyqprmdobe's Avatar
Default Re: nitrous ques? (urbansi)
You dont need a tach adaptor it should all hook up in the engine bay to the distributor. The ignition wire can be any switched 12v wire, like on the back of your stereo is a common one. When the switched is turned off then on again it starts up in the mode it should be in to run, but you need to calibrate it, # of cylinders, rpm on and rpm off.
The switches are real easy to work, my nissan came with one and I figured out how to use it without any help or manuals, the buttons are cleary labled as to what they do.
DarkBB4
Jun 15, 2007 12:43 PM
jnasty
Jan 30, 2007 06:47 PM
jnasty
Jan 30, 2007 06:28 PM
GdmLaz
13
Jun 10, 2005 06:34 AM
zcivic91
Jan 15, 2003 12:03 AM
