Nitrous on an EG
Old Jan 23, 2004 | 11:23 PM
SB97civic's Avatar
Default Nitrous on an EG
friend has an EG LX and wants to do a nitrous system. what're your thoughts?
Old Jan 23, 2004 | 11:27 PM
ARIZONA's Avatar
Default Re: Nitrous on an EG (SB97civ)
I say Wet, the D15 stock doesn't need DPI.
STIBungy's Avatar
wet is safer and easy to install.
Old Jan 23, 2004 | 11:37 PM
SB97civic's Avatar
Default Re: Nitrous on an EG (ARIZONA)
does wet system give same performace as DPI?
Old Jan 24, 2004 | 12:49 AM
-Trinitron-'s Avatar
no. DPI is a much more even and equal flow, since it has a individual nozzle per cylinder. not just blasting it into the intake. But a wet kit is still a good kit and a little cheaper,plus it is much less work. You dont have all that plumbing and drilling. I personally run a wet NX kit and of all the N20 kits I have had it is my favorite.
THE GUY
Old Jan 24, 2004 | 04:02 AM
sillvercivicgsr's Avatar
Default Re: (B18CBungy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CBungy &raquo;</TD></TR><TR><TD CLASS="quote">wet is safer and easy to install.</TD></TR></TABLE>
actually test have been done and the dry systems are safer than the wet
Old Jan 24, 2004 | 04:54 PM
SB97civic's Avatar
Default Re: (sillvercivicgsr)
it's not my car, one of my friends but he said if he does it he wants to do it right. so in that regard what's the word?
Old Jan 24, 2004 | 05:28 PM
JDM_Risa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sillvercivicgsr &raquo;</TD></TR><TR><TD CLASS="quote">
actually test have been done and the dry systems are safer than the wet</TD></TR></TABLE>
can i see these test
dry system is only safe when a small amount is used......such as a 50shot but anything over 75shot of NOS should be WET system
over 100shot should be Dp
keep in mine 2 step colder spark plugs
every 50 shot=2 degree of retarding
Old Jan 24, 2004 | 07:57 PM
Forrest Gump 9's Avatar
Default Re: (GunMETAL_TEgRa)
The best is wet and direct port. It's a little more work, and PITA to change jets, but it's well worth it.
Old Jan 24, 2004 | 08:03 PM
97hb's Avatar
I recommend a ZEX dry kit. Mine has been running strong for about 2 years no problems. Whenever someone says this kit is safer is crazy, 99% of the time is the installer/user that blow his engine with nitrous.
Old Jan 29, 2004 | 09:41 AM
SB97civic's Avatar
Default Re: Nitrous on an EG (97hb)
will direct port injection give the best results if you have the time and money to spend on that system?
Old Jan 29, 2004 | 11:52 AM
Distorted's Avatar
If you really want to know what the best set up is, i suggest directly contacting zex and speaking with one of their engineers. Y our getting a lot of great opinions most of which i hope are based on experience, but for solid info, go to the source. Dont ask sales, ask for an product engineer or tech representative, they are slightly less likely to upsell you, hehe.
Old Jan 29, 2004 | 12:25 PM
boosted92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SB97civ &raquo;</TD></TR><TR><TD CLASS="quote">will direct port injection give the best results if you have the time and money to spend on that system?</TD></TR></TABLE>
Yes, pretty much NO chance of puddling and no cylinder gets more juice than any others. Only downside is most direct port kits run at a much lower fuel pressure than your main fuel system, so you either have to sump the tank and run a seperate low pressure pump, or run a seperate fuel cell just for the nitrous.
Old Jan 29, 2004 | 01:11 PM
gitwidit's Avatar
Default Re: Nitrous on an EG (boosted92)
I was tuned for 100 shot dry on my last setup with Hondata Nitrous Controls, never had a problem. For the hell of it we pumped it to a 150 shot dry on C16 and I still couldn't blow it up
Old Jan 29, 2004 | 03:00 PM
booscivic's Avatar
I would go with 100shot direct port!
Old Jan 29, 2004 | 04:34 PM
RaceProfessor's Avatar
I'm assuming with the D15 you wouldn't do much more than a 50 shot. If so I'll just go with a basic dry kit for ease of installation and cost effectiveness. I had a NX wet kit on my GSR powered Civic and loved it but nothing wrong with the dry kit. DP might be a bit overkill for a stock D15.
Sam
Nikoli
Aug 14, 2005 01:25 PM
xfrankix2
May 17, 2005 09:35 PM
mongoliandonuts
Feb 26, 2005 02:09 PM
98rsteg
Apr 23, 2004 10:29 AM
redteg1
Dec 5, 2001 02:18 AM
