NGK Vs. MSD Superconductor Spark Plug Wires?
Old Jul 7, 2022 | 05:14 PM
Chance EG's Avatar
Default NGK Vs. MSD Superconductor Spark Plug Wires?
I'm noticing that NGK has two part numbers for wire sets for B series engines, does anyone know what the difference is?
NGK HE64
NGK HE57
Both are 7mm and direct OEM fit. I'm noticing the HE64 for some reason tend to cost a little more.
Alternatively, what are the thoughts on MSD Super Conductor wires? Is there any improvement with these on turbo builds? They use an 8.5mm wire/jacket which they claim helps reduce interference and wire degredation. Any thoughts or input is appreciated.
Also hello everyone.
Old Jul 8, 2022 | 11:38 AM
Chance EG's Avatar
Default Re: NGK Vs. MSD Superconductor Spark Plug Wires?
Paging JRCivic, Shodan, and AZ!
Old Jul 8, 2022 | 02:33 PM
Stopsign32v's Avatar
Loved
What are you expecting new MSD wires to do that NGK hasn't been doing?
Old Jul 8, 2022 | 04:25 PM
Chance EG's Avatar
Did you read the post?
Or, a better question, did you understand the post?
I'm asking why there are two different NGK part numbers for B series spark plug wires. I am also asking if there is any performance or reliability benefit comparing the NGK wires to the thicker MSD.
Old Jul 8, 2022 | 04:35 PM
Loved
I'm answering your "alternatively" part of your stupid ******* post since you are dying to get feedback with your gif. As far as what the difference is between the wires, have you thought about calling or emailing the company that makes them and ask them? Have you done any searching on the internet? Or are you simply looking for spoon fed information?
So again, let me try one more time...What are you expecting the MSD wires to do that NGK doesn't? Another question, do you see performance lacking with NGK wires? Are NGK wires not reliable? They have been used for the past what...20 years on this site?
Old Jul 8, 2022 | 04:40 PM
Chance EG's Avatar
Spicy.
I stopped reading after that. If a mod wants to close or delete this that's fine.
Old Jul 8, 2022 | 05:06 PM
Loved
HE64 is for B series and the HE57 is for what appears to be F series.
Old Jul 9, 2022 | 07:38 AM
highschooler's Avatar
On Amazon, how ever reliable that is, it says the HE57 does not fit a 1999 Acura Integra GS-R or a 2000 Honda Civic Si.
The HE64 says it fits a 2000 Honda Civic Si and a 1999 Acura Integra GS-R.
Where are you getting the info that says the HE57 is for the “B series”?
For more reliable info, maybe check Autozone because their database is more accurate than Amazon.
Old Jul 9, 2022 | 08:05 AM
The MSD red spark plug wires might be a little better. It’s difficult to measure the difference… I remember a long time ago lots of people would upgrade to the MSD red wires, distributor cap, and MSD blaster coil. That was before people did the Coil-On-Plug conversion. It was supposedly better for big HP, like over 400 or more. It didn’t really “add” anything, but supposedly “supported” more of a spark. They are like triple the price so it depends if your set up is not getting a good enough spark. I might add the red MSD wires to my set up at some point in the future.
Old Jul 9, 2022 | 06:39 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Folks, lets try and keep it friendly. Thank you.
Old Jul 9, 2022 | 07:33 PM
Bottlefedz28's Avatar
Loved
If you are in the market for a serious plug wire look no further than firecore performance. He doesn’t offer an off the shelf solution for Honda’s but he does custom wires. His credentials are out there if you look a little and he’s been on a couple of podcasts and has no issues with sharing technical information about his wires.
Old Jul 9, 2022 | 10:06 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
I have used MSD plug wires in the past... way in the past... and once I began using NGK wires, I never looked back. Affordable cost, excellent value and exceptionally reliable. The description for the NGK HE-57 (part #9428) says that they fit the 1990-91 Accord. So this plug wire set will NOT fit a "B" series application.
Old Jul 10, 2022 | 06:12 AM
jdblock's Avatar
I don't know what makes spark plug wires good, but you can test resistance to find bad wires.
Old Jul 11, 2022 | 03:31 PM
NVturbo's Avatar
O.G. triple O.G.
HE64 VTEC B series engines
HE57 F22A engine
HE82 non-VTEC B18B1 engines
YOU'RE WELCOME
Had a set of MSD wires a while back as well. They went bad out of the blue and I had to drive the car home on 3 cylinders. Not fun at all going no more than 35mph at WOT. lol
Nicks95GSR
Jul 11, 2008 09:16 AM
Blazen_angles
Dec 5, 2007 06:07 AM
GraphiteMW
Nov 7, 2006 03:55 PM
yeegsr
12
Oct 23, 2004 08:48 PM
