which NGK plugs to run?
Old Sep 28, 2010 | 07:25 AM
skuded's Avatar
Default which NGK plugs to run?
I need to know which plugs would be best to use on my all stock gsr, 9lbs of boost on an sc61, 300whp. Iriduim or platnium? i will be having t1 re-tune next monday so i want to make sure i have to right plugs
Old Sep 28, 2010 | 07:27 AM
93turbo16's Avatar
Default Re: which NGK plugs to run?
You can run regular NGK BKR7E plugs. The part number is 4644 at Advanced Auto.
Old Sep 28, 2010 | 07:34 AM
Bizzle5OH3's Avatar
Yes I agree BKR7E. I have them in my boosted SI and in my old Y8. I believe they run two steps colder than OEM, they are a must have and cheap also.
Old Sep 28, 2010 | 07:38 AM
skuded's Avatar
is it necessary to run a colder plug with a fairly mild setup like mine, i have 440 injectors, walbro 255 skunk 2 mani, holley tb, and all stock gsr with stock headgasket? also im on 9lbs of boost right now it stock headbolts, i can do headstuds, but i really want to leave the motor alone for now until i can build it, would i be safe running 11psi on the stock headbolts, i would really like to shoot for like 330 whp this time
Old Sep 28, 2010 | 07:41 AM
atec's Avatar
bkr7e is perfect and cheap for up to 400whp, remember to gap properly.
Old Sep 28, 2010 | 07:45 AM
skuded's Avatar
i will be asking tony at t1 which gap to run and installing before the tune
Old Sep 28, 2010 | 07:51 AM
Bizzle5OH3's Avatar
Im not sure if its ABSOLUTLY NECESSARY, but they are like 5 buck for all 4 and i would reccommend them. Your GSR headgasket is metal so it will be fine on 9 or 11 PSI along with your headstuds. Im on 10.5 on a stock motor and in going with 14 PSI when I get my new wastegate. Its all in the tune honestly. My buddy had a stock GSR running around 11 psi and it put down 333WHP on the dyno so 330 is possible. Depends on exhaust, manifold, size of turbo ext. Keep in mind though we are only 300 FT above sea level so 330 might be a little harder for you where you are.
Old Sep 28, 2010 | 07:54 AM
skuded's Avatar
well the turbo is an sc61 .63 inlet and .82 outlet, so i dont feel the turbo will have any trouble getting there. I just want to make sure im not going to lift the head off the motor at 11 psi? and also what are the alpha delphi 440 injectors good to as far as horspower ratings, im concerned they are to small
Old Sep 28, 2010 | 08:01 AM
Bizzle5OH3's Avatar
Turbo is good for that power goal, at 11PSI your head wont lift. your injectors will be fine for that power goal as well. ive seen 375hp on 440cc injectors.
Old Sep 28, 2010 | 08:23 AM
Topdawgg's Avatar
BKR7E or BKR8E
Old Sep 28, 2010 | 08:39 AM
atec's Avatar
Originally Posted by Topdawgg
BKR7E or BKR8E
where did you find BKR8E plugs? I dont think NGK makes them, BKR8 EIX in that case.
Old Sep 29, 2010 | 07:01 AM
EG6 Love's Avatar
BKR7E. i had to jump through some hoops to get these because nobody around me sold them. now i have 8 extra.
Old Sep 29, 2010 | 02:29 PM
DDTECH's Avatar
Copper v-power plugs i'd run 8's personally.
Old Sep 29, 2010 | 04:20 PM
ashb82's Avatar
NGK 4554
But if you got hondata forget it
Old Sep 29, 2010 | 09:57 PM
slowtegkauai's Avatar
Originally Posted by ashb82
NGK 4554
Why? Are those non resistor plugs? as long as they have an R for resistor than you should be fine.
Old Sep 30, 2010 | 09:56 AM
welfarepc's Avatar
non-resistor plugs work fine on almost all EMS except S300.
what ever you do, dont use platinum plugs. the platinum tip acts as a catalyst and can cause u a LOT of combustion problems.
Old Sep 30, 2010 | 02:21 PM
blackeg's Avatar
good to know about the non resistor plugs and s300.
bkr 7e's are good for over 400 hp. i made like 430 with them at .020 gap a lil while ago and plan on 450 with them gapped around .018ish.
incidentally, i just went to advanced to get me some more 4644's and the useless counterperson said they dont have them anymore. thank god i've got a napa in town.
Old Sep 30, 2010 | 03:42 PM
skuded's Avatar
so your saying bkr7e's arent good for my setup, since i will not be running anywhere close to 400whp?
Old Sep 30, 2010 | 03:44 PM
Bizzle5OH3's Avatar
They are good FOR OVER 400HP. There isnt a minimum
Old Sep 30, 2010 | 07:21 PM
skuded's Avatar
i just got done doing the valve adjustment on my gsr, and the plugs that came in it were BKR6E's i will be replacing these on the day of my tune, but just wondering if anyone has had any experience with these and are they a colder plug or just an oem ngk for the gsr?
Old Sep 30, 2010 | 07:36 PM
Garage 808 Hatch's Avatar
I'm doing just fine at 800whp on non resistor plugs with s300. Stock number 7173 bkr8e
Old Oct 1, 2010 | 05:27 AM
blackeg's Avatar
they are the oem plug for the vtec b series' motors. the 7e's will be fine, id go with that
Old Oct 1, 2010 | 09:31 PM
jetspeedz's Avatar
The issue is more with regards to data logging on s300 and non resistor plugs. Also I was under the impression if there is a "r" then it is a resistor plug so your bkr8e are actually resistor plugs.
i run the 4644 and get them from summit over 400hp all day long no issues
http://www.summitracing.com/parts/NGK-4644/
mr_munro
May 31, 2012 08:01 PM
CMCivicSI
Jan 6, 2006 06:15 PM
Racerage1
Apr 3, 2003 09:28 AM
Qwikrex
11
Jan 20, 2003 11:52 PM
GRAVEDIGGER
Jun 18, 2002 01:48 PM
