Next Mod?
Old Nov 12, 2001 | 08:19 PM
97integraLST's Avatar
Default Next Mod?
what should I do next?
injectors+Fuel Pump= run higher boost 10-11 LBS instead of 9
Test pipe= add 15-20+ HP
Act Clutch= Put more Power to the ground? Also should i get a lightened flywheel?
or any others that would have a Major increase... thanks.
Also for the injectors I will probably get the RC 440cc, what fuel pump should i get?
THANK YOU FOR ANY RepLIES
Old Nov 12, 2001 | 09:12 PM
TurboIntegra's Avatar
Default Re: Next Mod? (97integraLST)
You dont have a fuel pump??? If you don't then I would for sure get that.
When I had my Turbo LS, the test pipe was one of the BEST mods I ever did. I would do that, just because it is really cheap and I assure you, you willl get more power and quicker spool up.
Old Nov 12, 2001 | 09:15 PM
DIRep972's Avatar
Smarter than you
definitly do the test pipe..
u will need the clutch sooner or later..
your turbo kit came with a fuel pump.. if u get a better one it wont allow u to run higher boost thats more a duty of the injectors and ECU
Old Nov 13, 2001 | 03:07 AM
Default Re: Next Mod? (DIRep972)
it came with an MSD fuel pump. ITs junk though, so loud
Old Nov 13, 2001 | 04:35 AM
GSRacer's Avatar
New User
u should get 370's instead of 440's if your going to control it w/ an AFC
[Modified by GSRacer, 5:35 AM 11/13/2001]
Old Nov 13, 2001 | 06:57 AM
dustin's Avatar
Default Re: Next Mod? (GSRacer)
Good fuel pumps are loud.
Old Nov 13, 2001 | 07:01 AM
VaporTrail's Avatar
New User
Default Re: Next Mod? (dustin)
The Bosch "big ***" fuel pump (coke can sized) isn't loud so long as you do not mount it in tank. It's actually somewhat livable!
Old Nov 13, 2001 | 07:23 AM
rtype11's Avatar
Default Re: Next Mod? (VaporTrail)
I have my Bosch with a silicone hose around it mounted to my fire wall where the stock fuel filter was. Its not so loud as i have 100 other tings on my car that are louder, in anycase the silcone hose (for I/C tubing) quiets it down a bit and doesnt really make it run much hotter than uncovered.
P.S. next mod - one of those huge wings with dual levels and splitter and indy pace car lights on em....buy yours at http://www.bigasshugewingsusa.com....so that I can make fun of your car later on.
[Modified by rtype11, 8:23 AM 11/13/2001]
Old Nov 13, 2001 | 07:55 AM
maxim's Avatar
Default Re: Next Mod? (rtype11)
My suggestion would be to get the clutch and flywheel combo first. You will have to get rid of the stock clutch anyway.
CaptainBuster
Jul 15, 2014 03:39 PM
project dc2
Mar 31, 2010 06:04 PM
n01civic
Jun 13, 2006 02:36 PM
smoothludey2
Oct 1, 2001 03:27 PM
