newbie turbo question
Old Jul 27, 2003 | 01:37 AM
dtec's Avatar
Default newbie turbo question
if the intercooler pipes go to the throttle body, where does the intake go? can you have a cold air intake with a turbo intercooler? sorry for such a noob question.
Old Jul 27, 2003 | 01:43 AM
Charles B.'s Avatar
Default Re: newbie turbo question (dtec)
your "intake" pipe looks like a CAI and is routed to one end of your intercooler. more piping is routed from the other end of the intercooler to the compressor outlet on the turbo. so air goes from your turbo, through the piping, through your intercooler, through more piping, through your "intake" and to the throttle body. hth.
Old Jul 27, 2003 | 01:53 AM
g2ls_turbo's Avatar
this is a newb question huh...anyways, yeah, i got mines cold air with intercool. works pretty good, turbo sounds louder too. the cold air intake pipe goes on the turbo housing, the grey part (snail) and find its way outside of the engine bay for cold air.
Old Jul 27, 2003 | 02:01 AM
romeo619romeo's Avatar
Default Re: (g2ls_turbo)
thats just waiting for water to get sucked into...if you have a front mount.. it shoudlnt really matter.. spray water on the intercooler instead to drop the charge temps
Old Jul 27, 2003 | 02:03 AM
dtec's Avatar
Default Re: (romeo619romeo)
so with a front mount intercooler, you don't need a CAI? i don't get it. i thought that one end of the turbo gets connected to the downpipe, and the other end of the turbo gets connected to the intercooler, which is then connected to the throttle body, right? sorry again, i'm still learning when it comes to turbos.
Old Jul 27, 2003 | 02:17 AM
ffgeon's Avatar
Default Re: (dtec)
http://auto.howstuffworks.com/turbo2.htm try that
Old Jul 27, 2003 | 03:03 AM
FredoSP's Avatar
Default Re: (dtec)
I think a nice diagram would help you out a lot.
99% of the turbo guys on here (1% are a screen mesh and pantie hose users) add a filter to the compressor side of the turbo. That is essentially your intake per say. When the wheel is spinning it is sucking air into it, and we want to make sure no **** is in there (water, bugs, etc) to damage the blades. I mean if your asking can u run a "cold air intake" i GUESS you could, but why. That's why you have an intercooler, to cool the intake temps. The air you are sucking up is only going to get heated by the turbo anyways (remember the turbo absorbs A LOT of heat, thats why most turbo cars aren't that loud compared to N/A cars).
Here a pic of my old greddy "intake", its the mushroom looking filter ..Hope this helps. Try and read that turbo stuff on the web, I think its pretty good.
Top view
See the pipes as they go into the turbo. The other side, (HOT) goes to your exhaust system.
Old Jul 27, 2003 | 11:05 AM
dtec's Avatar
Default Re: (FredoSP)
wow thanks you guys helped out alot. i posted this same question at the "other" honda forum and nobody bothered to answer me. i'm moving here instead now!
Old Jul 27, 2003 | 11:23 AM
Pelican's Avatar
Default Re: (dtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dtec &raquo;</TD></TR><TR><TD CLASS="quote">wow thanks you guys helped out alot. i posted this same question at the "other" honda forum and nobody bothered to answer me. i'm moving here instead now!</TD></TR></TABLE>
Good Idea
But there is No Other Honda Forum but Honda-Tech
chadalac1712
99
Feb 25, 2007 09:18 AM
elevtro
11
Jul 11, 2004 05:38 PM
nota-ex
29
Mar 27, 2004 07:50 AM
servion
Jul 21, 2003 02:30 PM
f@sth@tch89
14
Jul 6, 2003 03:40 PM
