newbe needs help
Old Feb 1, 2005 | 10:16 AM
SI2SLOW's Avatar
Default newbe needs help
Hey guys, I need some help. I just got done putting together my 2000 si with greedy kit. But a week ago good friend of mine blew up his motor and he's selling me his drag kit dirt cheap. Everything will bolt right up, except the downpipe. My greedy down pipe is weilded to the mid-section of my Greedy evo. He's willing to give me his mid section, which is great. Now heres the problem, he has a 94 civic coupe with one o2 sensor. I have 2000 SI with 2 sensors. Can I make hes mid work on mine. If you guys need more info please let me know. Thank you. By the way planning on runing Hondata.
Old Feb 1, 2005 | 11:05 AM
respectblades's Avatar
Default Re: newbe needs help (SI2SLOW)
if your running hondata you might as well go obd1
in fact someone correct if i'm wrong but he may actually have to go to obd1
since your going to use his drag kit just have a place that does exhaust do a little cutting and welding or purchase another exhuast outright
byt he way its greddy not greedy
Old Feb 1, 2005 | 11:14 AM
SI2SLOW's Avatar
Default Re: newbe needs help (respectblades)
Thank you for response, and also thank you for the correction. Just spoke to In-line pro rep. He said that it should not be a problem because hondata uses only one sensor, and yes im gonna use p30 from my friends car. By the way only reason I put "greedy" is to get you guys going. I have read all the helpful topics on here for year and half, just didn't post because didn't have the car. Next post will be my dyno numbers.
Old Feb 1, 2005 | 04:26 PM
JDEM1's Avatar
hondata = obd1 = 1 sensor = yes your friends midsection will work on your car, but also you need to spend the cash for the hondata with boost, the obd2-1 adapter, and the obd1 ecu itself..
Old Feb 1, 2005 | 04:27 PM
93turbo16's Avatar
Yea, I would say get the engine management first. And just convert to OBD1, like everyone else already stated.
Old Feb 1, 2005 | 04:50 PM
SI2SLOW's Avatar
Default Re: newbe needs help (JDEM1)
I am doing that as soon as we get the car together. Weather isn't helping right now. I have spent alot of money on the motor allready, not going to throw that away by running the hack. Anyway I got my friends P30 and will buy the rest throw inline pro. Thank you for you help. Also I will write down my whole setup.
Benjithx
Jun 9, 2004 08:41 PM
Crackerballer
Jan 16, 2004 10:15 PM
Crackerballer
Jan 13, 2004 08:50 PM
JDM_EH2
Dec 1, 2003 09:50 AM
ImportFreek
Dec 20, 2002 05:01 AM
