New turbo, many problems
Old Apr 28, 2014 | 06:26 PM
sonno's Avatar
Default New turbo, many problems
I have a d16z6 that I've just finished installing a 60 trim on. I've had all of these problems with both stock chip and a generic 8psi turbo 450cc basemap. I've got stock injectors now because I'm scared adding fuel could create more problems. Thanks for any input.
So 1) Before the turbo, my motor would max at 105 mph. Now it won't go past 85 downhill.
2) My wideband sensor almost always reads 19 afr, and it sends simulated nb to my computer, so I'm guessing it's running rich to compensate, but I guess it could actually be lean.
3) After reaching 85 mph, I get a cloud of blue smoke, the size seems to correlate to how long I keep the pedal down. I can floor it from 0 to 60 without smoking, though, and it hasn't ever smoked while in throttle.
4) Acceleration seems to have sweet spots in the throttle that pull strong, but more or less pedal and my power disappears.
Old Apr 28, 2014 | 06:32 PM
b16racereg6's Avatar
Default Re: New turbo, many problems
You need a tune. Before that Read the FAQ.........
Old Apr 28, 2014 | 06:34 PM
wantboost's Avatar
Who is Mr Robot?
Stop right now.
stock injectors, stock pump, stock ecu under boost is dangerously lean. you've probably already damaged the motor.
the stock ecu can't see positive pressure so the car should be totally undrivable.
Old Apr 28, 2014 | 06:40 PM
sonno's Avatar
Well it's definitely not undrivable. Are you saying a tune could fix all these issues?
Old Apr 28, 2014 | 07:43 PM
boostlsveg's Avatar
A tune SHOULD fix it. If u didn't already damage the motor.
Old Apr 28, 2014 | 11:35 PM
wantboost's Avatar
Who is Mr Robot?
The stock ecu doesn't add enough fuel and the timing is wrong. THE STOCK ECU CANNOT SEE POSITIVE PRESSURE FROM THE MAP SENSOR. IT PUTS THE CAR IN LIMP MODE
STOP DRIVING THE ******* THING AND GET IT TUNED
or keep driving and crack a ringland (probably already happened) pop a headgasket, or break a sleeve, throw a rod, etc.
Old Apr 29, 2014 | 04:25 AM
Schister66's Avatar
Man U FTW
Wow...
Unless you want to rebuild/replace that engine, you had better get a tune. The stock injectors can't handle that fuel demand, the stock ECU doesn't understand or adjust for boost, and without a tune to speak of, you're running dangerously lean in your so-called 'sweet spots'. Its only a matter of time until you either crack a ringland/sleeve or melt a hole in a piston...
This is why you research BEFORE you boost, not after
Old Apr 29, 2014 | 05:41 AM
sonno's Avatar
So bypassing all the flame, I'm feeling Kevlar this morning, I should leave the basemap i have and install my 450s. Any other advice?
Old Apr 29, 2014 | 05:49 AM
Dark_Teg's Avatar
Before doing anything else do a compression test. If what you say is true your ring lands are probably toast.
Old Apr 29, 2014 | 06:19 AM
sonno's Avatar
Ok. Will do. And if they're okay, I should install the injectors?
Old Apr 29, 2014 | 06:32 AM
boostjunkie757's Avatar
after installing the injectors id get it towed to the dyno to be tuned..
provided you dont need to install a new engine first.
Old Apr 29, 2014 | 07:32 AM
SovXietday's Avatar
You've already ruined everything it sounds like.
Old Apr 29, 2014 | 08:52 AM
crxtc_vtec's Avatar
I'd worry about installing a new engine, lol to hell with the new injectors lmao
Old Apr 29, 2014 | 11:34 AM
sonno's Avatar
To all the band wagoneers, compression test read 210 across them all.
Old Apr 29, 2014 | 11:46 AM
Schister66's Avatar
Man U FTW
Band-wagoners? Dont act so ******* smug...You've gotten lucky so far, but that luck will run out.
Old Apr 29, 2014 | 12:04 PM
dont pat yourself on the back too hard sonny..
dont wanna break your own spine. consider yourself lucky, learn your lesson and you too can grow..
Old Apr 29, 2014 | 03:27 PM
wantboost's Avatar
Who is Mr Robot?
Drivable... Lol a 19:1 air fuel ratio is so far from drivable and safe it's not even funny.
bandwagons have **** all to do with the fact that you're doing it wrong.
put your 450s in, scale a basemap for the injectors and get it tuned immediately. don't drive it and don't beat on it. tow it.
the pistons have no doubt been weakened by extremely lean air fuel mixtures and highly excessive combustion chamber and exhaust gas temps.
you've simply gotten lucky, the way you were beating on that motor with a stock ecu it should have destroyed a piston or two.
Old Apr 29, 2014 | 05:07 PM
1994civ's Avatar
Dang
Old Apr 29, 2014 | 05:18 PM
Slacker93eg's Avatar
10 Year Member
^ Good first post contribution.
Old Apr 29, 2014 | 05:59 PM
TravisBiggie's Avatar
you're asking for "advice" when all this post is, is advice.... READ, and COMPREHEND....
You know what I did when I installed different injectors?
I took my ecu to a local tuner and asked him to edit it for my injectors ( I did this on two occassions) with 450s, and 1000ccs, and drove it to the tuner gently (5 miles max) Seriously, you're stupid if you boosted the thing completely stock... You can't just throw a ******* turbo on it and whale on it.
OF COURSE IT RUNS LIKE ****, ITS NOT ******* TUNED!!!
part of me wants the motor to be garbage so you learn a valuable lesson. Also you should appreciate the help you get here, we don't have to help you.
Originally Posted by 1994civ
Dang
lold
Old Apr 29, 2014 | 06:04 PM
turbohatch96y7's Avatar
I ******* LOLD at installing a turbo and not going past 85mph DOWNHILL
Your mind mustve been blown to ****
Old Apr 29, 2014 | 07:32 PM
wantboost's Avatar
Who is Mr Robot?
Oh lawd
Old Apr 29, 2014 | 08:56 PM
sonno's Avatar
Yeah. It's probably already blown up! Yeah! Wait, was that already said? Damn. I thought I was being helpful...
Old Apr 29, 2014 | 09:00 PM
sonno's Avatar
Side note, I bet two other people on this thread have actually installed a turbo on their own vehicle. I've come to learn. If that's not what this site is for, I'll find another way. No worries.
Old Apr 29, 2014 | 09:32 PM
F22Master's Avatar
Most people learn BEFORE they do things, so they dont **** up. You've already fucked up.
Just remember, there's only one idiot in this thread...
